Hello, decided to try Jetpack 5 on Jetson NX, but faced this ussie, during Flashing Jetson NX with sdkmanager:
20:32:32.159 - error: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS: 131072+0 records in
20:32:32.159 - info: Event: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS - error is: 131072+0 records in
20:32:32.160 - error: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS: 131072+0 records out
20:32:32.160 - info: Event: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS - error is: 131072+0 records out
20:32:32.160 - error: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS: 67108864 bytes (67 MB, 64 MiB) copied, 0.212177 s, 316 MB/s
20:32:32.160 - info: Event: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS - error is: 67108864 bytes (67 MB, 64 MiB) copied, 0.212177 s, 316 MB/s
20:32:32.194 - info: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS: formating FAT filesystem on esp.img failed.
20:32:32.194 - info: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS: Cleaning ESP mounts..
20:32:32.197 - error: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS: *** ERROR: flashing failed.
20:32:32.197 - info: Event: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS - error is: *** ERROR: flashing failed.
20:32:32.200 - info: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS: [ Component Install Finished with Error ]
looks like this is the error:
here is log file:
sdkm-2022-04-15-20-30-00.log (242.2 KB)
