I have a Jetson Xavier NX 16GB and using NVMe as the main boot and storage. My old SSD works fine but when I tried to flash a new SSD it always failed because of multiple errors. I tried different JetPack version but always failed to flash the new SSD. I put back the old SSD and it was able to boot to Ubuntu home without any problems.
23:55:04 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 400000
23:55:12 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 410000
23:55:15 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 420000
23:55:22 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 430000
23:55:29 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 440000
23:55:33 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 450000
23:55:43 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 460000
23:55:50 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 470000
23:56:25 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 480000
23:56:35 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 490000
23:56:44 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 500000
23:57:25 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 510000
23:57:27 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 520000
23:57:28 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 530000
23:57:29 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 540000
23:57:30 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 550000
23:57:32 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 560000
00:01:35 ERROR: Flash Jetson Linux - flash: 42010 blocks
00:01:35 ERROR: Flash Jetson Linux - flash: gzip: /home/haritsahm/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
00:01:42 ERROR: Flash Jetson Linux - flash: 58247 blocks
00:01:43 ERROR: Flash Jetson Linux - flash: 20+0 records in
00:01:43 ERROR: Flash Jetson Linux - flash: 20+0 records out
00:01:43 ERROR: Flash Jetson Linux - flash: 20 bytes copied, 0.000488648 s, 40.9 kB/s
00:01:46 ERROR: Flash Jetson Linux - flash: 131072+0 records in
00:01:46 ERROR: Flash Jetson Linux - flash: 131072+0 records out
00:01:46 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0.653557 s, 103 MB/s
00:01:54 ERROR: Flash Jetson Linux - flash: /home/haritsahm/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
00:01:54 ERROR: Flash Jetson Linux - flash: /home/haritsahm/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
00:02:00 ERROR: Flash Jetson Linux - flash: 58247 blocks
00:02:07 ERROR: Flash Jetson Linux - flash: 87006 blocks
00:05:54 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.haritsahm.sh; [error]: 87006 blocks
00:05:54 ERROR: Flash Jetson Linux - flash: command terminated with error
00:05:54 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
00:05:54 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
00:05:54 SUMMARY: Multimedia API - target: Depends on failed component
00:05:54 SUMMARY: TensorRT on Target - target: Depends on failed component
00:05:54 SUMMARY: TensorRT Runtime - target: Depends on failed component
00:05:54 SUMMARY: VPI on Target - target: Depends on failed component
00:05:54 SUMMARY: VPI Runtime - target: Depends on failed component
00:05:54 SUMMARY: CuPVA Runtime - target: Depends on failed component
00:05:54 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
00:05:54 SUMMARY: CUDA Runtime - target: Depends on failed component
00:05:54 SUMMARY: cuDNN on Target - target: Depends on failed component
00:05:54 SUMMARY: CuDNN Runtime - target: Depends on failed component
00:05:54 SUMMARY: OpenCV - target: Depends on failed component
00:05:54 SUMMARY: OpenCV Runtime - target: Depends on failed component
00:05:54 SUMMARY: DeepStream - target: Depends on failed component
00:05:54 SUMMARY: DateTime Target Setup - target: Depends on failed component
SDKM_logs_JetPack_5.1.1_(rev._1)_Linux_for_Jetson_Xavier_NX_modules_2023-11-06_09-39-08.zip (349.9 KB)
SDKM_logs_JetPack_5.1.2_Linux_for_Jetson_Xavier_NX_modules_2023-11-06_02-17-42.zip (384.7 KB)
SDKM_logs_JetPack_5.1.2_Linux_for_Jetson_Xavier_NX_modules_2023-11-06_23-39-06.zip (178.7 KB)
d
