Xavier NX Installation Failed
I’m trying to flash a brand new Xavier NX on a Diamond Systems Floyd carrier board with JetPack 5.0.2 Flashing fails on the “Flash Jetson Linux” step.
I’ve jumpered the Force Recovery pins on the Utility connector but I’m getting an “installation error” in SDK Manager.
The process finishes “Step 2: Boot the device with flash initrd image” but fails on “Step 3: Start the flashing process”.
The host machine is Ubuntu 20.04 (not a VM).
I’ve attached the logs zip file. Below are the last ~200 lines of NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP.log:
[   3.2256 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 232736
[   3.2515 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 206016
[   3.2518 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 24016
[   3.2520 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 145184
[   3.2522 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3430416
[   3.2531 ] Added binary blob_bpmp-2_t194_sigheader.bin.encrypt of size 1007392
[   3.2539 ] Added binary blob_tegra194-a02-bpmp-p3668-a00_lz4_sigheader.dtb.encrypt of size 36192
[   3.2543 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 95232
[   3.2546 ] Added binary blob_tos-optee_t194_sigheader.img.encrypt of size 882112
[   3.2549 ] Added binary blob_eks_sigheader.img.encrypt of size 5136
[   3.2551 ] Added binary blob_boot0.img of size 56014848
[   3.2826 ] Added binary blob_tegra194-p3668-0000-p3509-0000.dtb of size 323817
[   3.2938 ] Added binary blob_tegra194-p3668-0000-p3509-0000_sigheader.dtb.encrypt of size 327920
[   3.3244 ] Sending bootloader and pre-requisite binaries
[   3.3264 ] tegrarcm_v2 --instance 3-1 --download blob blob.bin
[   3.3277 ] Applet version 01.00.0000
[   3.3490 ] Sending blob
[   3.3491 ] [                                                ] 001%
[   3.3491 ] [.                                               ] 003%
[   3.3491 ] [..                                              ] 005%
[   3.3491 ] [...                                             ] 006%
[   3.3491 ] [....                                            ] 008%
[   3.3491 ] [.....                                           ] 010%
[   3.3491 ] [.....                                           ] 011%
[   3.3491 ] [......                                          ] 013%
[   3.3491 ] [.......                                         ] 015%
[   3.3491 ] [........                                        ] 016%
[   3.3491 ] [.........                                       ] 018%
[   3.3491 ] [..........                                      ] 020%
[   3.3491 ] [..........                                      ] 021%
[   3.3491 ] [...........                                     ] 023%
[   3.3491 ] [............                                    ] 025%
[   3.3491 ] [.............                                   ] 026%
[   3.3491 ] [..............                                  ] 028%
[   3.3491 ] [...............                                 ] 030%
[   3.3491 ] [...............                                 ] 031%
[   3.3491 ] [................                                ] 033%
[   3.3491 ] [.................                               ] 035%
[   3.3491 ] [..................                              ] 036%
[   3.3491 ] [...................                             ] 038%
[   3.3491 ] [....................                            ] 040%
[   3.3491 ] [....................                            ] 041%
[   3.3491 ] [.....................                           ] 043%
[   3.3491 ] [......................                          ] 045%
[   3.3491 ] [.......................                         ] 046%
[   3.3491 ] [........................                        ] 048%
[   3.3491 ] [.........................                       ] 050%
[   3.3491 ] [.........................                       ] 051%
[   3.3491 ] [..........................                      ] 053%
[   3.3491 ] [...........................                     ] 055%
[   3.3491 ] [............................                    ] 056%
[   3.3491 ] [.............................                   ] 058%
[   3.3491 ] [..............................                  ] 060%
[   3.3491 ] [..............................                  ] 061%
[   3.3491 ] [...............................                 ] 063%
[   3.3491 ] [................................                ] 065%
[   3.3491 ] [.................................               ] 066%
[   3.3491 ] [..................................              ] 068%
[   3.3491 ] [...................................             ] 070%
[   3.3491 ] [...................................             ] 071%
[   3.3491 ] [....................................            ] 073%
[   3.3491 ] [.....................................           ] 075%
[   3.3491 ] [......................................          ] 076%
[   3.3491 ] [.......................................         ] 078%
[   3.3491 ] [........................................        ] 080%
[   3.3491 ] [........................................        ] 081%
[   3.3491 ] [.........................................       ] 083%
[   3.3491 ] [..........................................      ] 085%
[   3.3491 ] [...........................................     ] 086%
[   3.3491 ] [............................................    ] 088%
[   3.3491 ] [.............................................   ] 090%
[   3.3491 ] [.............................................   ] 091%
[   3.3491 ] [..............................................  ] 093%
[   3.3491 ] [............................................... ] 095%
[   3.3491 ] [................................................] 096%
[   3.3491 ] [................................................] 098%
[   3.3491 ] [................................................] 100%
[  14.2391 ] tegrarcm_v2 --instance 3-1 --boot rcm
[  14.2412 ] Applet version 01.00.0000
[  14.2750 ] RCM-boot started
/home/jairo/nvidia/nvidia_sdk/JetPack_5.0.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra
*  Step 3: Start the flashing process *
Waiting for target to boot-up...
Timeout
Cleaning up...
11:02:23.961 - Info: [ Component Install Finished with Error ]
11:02:23.962 - Info: [host] [ 158.35 MB used. Disk Avail: 810.40 GB ]
11:02:23.963 - Info: [ NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP Install took 4m27s ]
SDKM_logs_JetPack_5.0.2_(rev.1)_Linux_for_Jetson_Xavier_NX_modules_2022-09-14_10-57-42.zip (362.6 KB)
SDKManager supports flashing developer kit. If you use custom carrier board, please check with the board vendor for the system image.
Hi @DaneLLL, thank you for the reply. The vendor does provide a BSP for their carrier board but that also fails to flash with an error that reads Invalid value MemBct dram size: 0MB for slot: 2..
The top of the log file displays some information about it.
# L4T BSP Information:
# R32 , REVISION: 4.3
# Target Board Information:
# Name: jetson-xavier-nx-devkit-emmc, Board Family: t186ref, SoC: Tegra 194,
# OpMode: production, Boot Authentication: NS,
The log file from that flash.sh utility is attached here:flash_log.txt (30.1 KB). The last few lines from that log file are:
[   5.0130 ] Sending BCTs
[   5.0151 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[   5.0168 ] Applet version 01.00.0000
[   5.1089 ] Sending bct_bootrom
[   5.1091 ] [................................................] 100%
[   5.1109 ] Sending bct_mb1
[   5.1158 ] [................................................] 100%
[   5.1209 ] Sending bct_mem
[   5.1723 ] [................................................] 100%
[   5.1800 ] 0000000000000102: E> NONE: Invalid value MemBct dram size: 0MB for slot: 2.
[   5.1979 ]
[   5.1979 ]
Error: Return value 2
Command tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
Failed flashing t186ref.
Please contact with the vendor to get their support for the flash and device boot problem.
