larche
September 22, 2023, 6:14am
1
Hello.
When flashing Xavier NX, the following error occurs.
Error: Return value 8
Command tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
Failed flashing t186ref.
I want to know why this is the case.
The SDK version is JetPack5.1.1(R35.3.1).
(An error occurs even when using SDK Manager.)
xavier_nx_error.log (39.8 KB)
DaveYYY
September 22, 2023, 6:46am
3
Is it a DevKit or a custom carrier board?
Please also capture the serial console log here.
larche
September 22, 2023, 7:23am
4
This is a DevKit board.
Other Xavier-NX modules operate normally.
(This symptom occurred in two or three out of 300 CPU modules.)
NV_L4T_FLASH_JETSON_LINUX_COMP.log (48.8 KB)
DaveYYY
September 22, 2023, 7:26am
5
I mean serial console log from the device, not flashing log from the host.
If the issue persists on certain modules, while others are working fine, then sounds like it may be some hardware failure.
larche
September 25, 2023, 5:14am
6
Hello DareYYY.
This is the console log.
xavier_nx_console_log.txt (5.4 KB)
DaveYYY
September 25, 2023, 5:23am
8
It looks like some issues with BPMP/MB1, and if you are sure it only happened on a few modules, while other are still working fine, then please RMA those problematic modules.
