Jetson Xavier NX Installation Failed on Step 3: Start the flashing process
I tried to flash Jetson Xavier NX Developer Kit with JetPack 5.1 Flashing failed on the "Step 3: Flash Jetson Linux” step.
The process finished “Step 2: Boot the device with flash initrd image ” but fails on “Step 3: Start the flashing process ”.
The host machine is Ubuntu 18.04 on virtualbox
here is the log
NV_L4T_FLASH_JETSON_LINUX_COMP.log (189.0 KB)
full logs
SDKM_logs_JetPack_5.1_(rev._1)_Linux_for_Jetson_Xavier_NX_modules_2023-05-11_10-15-17.zip (154.5 KB)
[   2.4305 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 233040
[   2.6044 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 206016
[   2.6051 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 24016
[   2.6111 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 145184
[   2.6115 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3430416
[   2.6162 ] Added binary blob_bpmp-2_t194_sigheader.bin.encrypt of size 1007392
[   2.6222 ] Added binary blob_tegra194-a02-bpmp-p3668-a00_lz4_sigheader.dtb.encrypt of size 36176
[   2.6229 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 95232
[   2.6233 ] Added binary blob_tos-optee_t194_sigheader.img.encrypt of size 914992
[   2.6242 ] Added binary blob_eks_t194_sigheader.img.encrypt of size 5136
[   2.6247 ] Added binary blob_boot0.img of size 56109056
[   2.8256 ] Added binary blob_kernel_tegra194-p3668-0001-p3509-0000.dtb of size 323861
[   2.8602 ] Added binary blob_tegra194-p3668-0001-p3509-0000_sigheader.dtb.encrypt of size 338048
[   3.0698 ] Sending bootloader and pre-requisite binaries
[   3.0804 ] tegrarcm_v2 --instance 1-2 --download blob blob.bin
[   3.0816 ] Applet version 01.00.0000
[   3.1050 ] Sending blob
[   3.1051 ] [                                                ] 001%
[   3.1051 ] [.                                               ] 003%
[   3.1051 ] [..                                              ] 005%
[   3.1051 ] [...                                             ] 006%
[   3.1051 ] [....                                            ] 008%
[   3.1051 ] [.....                                           ] 010%
[   3.1051 ] [.....                                           ] 011%
[   3.1051 ] [......                                          ] 013%
[   3.1051 ] [.......                                         ] 015%
[   3.1051 ] [........                                        ] 016%
[   3.1051 ] [.........                                       ] 018%
[   3.1051 ] [..........                                      ] 020%
[   3.1051 ] [..........                                      ] 021%
[   3.1051 ] [...........                                     ] 023%
[   3.1051 ] [............                                    ] 025%
[   3.1051 ] [.............                                   ] 026%
[   3.1051 ] [..............                                  ] 028%
[   3.1051 ] [...............                                 ] 030%
[   3.1051 ] [...............                                 ] 031%
[   3.1051 ] [................                                ] 033%
[   3.1051 ] [.................                               ] 035%
[   3.1051 ] [..................                              ] 036%
[   3.1051 ] [...................                             ] 038%
[   3.1051 ] [....................                            ] 040%
[   3.1051 ] [....................                            ] 041%
[   3.1051 ] [.....................                           ] 043%
[   3.1051 ] [......................                          ] 045%
[   3.1051 ] [.......................                         ] 046%
[   3.1051 ] [........................                        ] 048%
[   3.1051 ] [.........................                       ] 050%
[   3.1051 ] [.........................                       ] 051%
[   3.1051 ] [..........................                      ] 053%
[   3.1051 ] [...........................                     ] 055%
[   3.1051 ] [............................                    ] 056%
[   3.1051 ] [.............................                   ] 058%
[   3.1051 ] [..............................                  ] 060%
[   3.1051 ] [..............................                  ] 061%
[   3.1051 ] [...............................                 ] 063%
[   3.1051 ] [................................                ] 065%
[   3.1051 ] [.................................               ] 066%
[   3.1051 ] [..................................              ] 068%
[   3.1051 ] [...................................             ] 070%
[   3.1051 ] [...................................             ] 071%
[   3.1051 ] [....................................            ] 073%
[   3.1051 ] [.....................................           ] 075%
[   3.1051 ] [......................................          ] 076%
[   3.1051 ] [.......................................         ] 078%
[   3.1051 ] [........................................        ] 080%
[   3.1051 ] [........................................        ] 081%
[   3.1051 ] [.........................................       ] 083%
[   3.1051 ] [..........................................      ] 085%
[   3.1051 ] [...........................................     ] 086%
[   3.1051 ] [............................................    ] 088%
[   3.1051 ] [.............................................   ] 090%
[   3.1051 ] [.............................................   ] 091%
[   3.1051 ] [..............................................  ] 093%
[   3.1051 ] [............................................... ] 095%
[   3.1051 ] [................................................] 096%
[   3.1051 ] [................................................] 098%
[   3.1051 ] [................................................] 100%
[  15.7476 ] tegrarcm_v2 --instance 1-2 --boot rcm
[  15.7492 ] Applet version 01.00.0000
[  15.8642 ] RCM-boot started
~/nvidia/nvidia_sdk/JetPack_5.1_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra
*  Step 3: Start the flashing process *
Waiting for target to boot-up...
Timeout
Cleaning up...
10:31:12.194 - Info: [ Component Install Finished with Error ]
10:31:12.196 - Info: [host] [ 16.29 GB used. Disk Avail: 36.74 GB ]
10:31:12.196 - Info: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 14m17s ]
screenshoot:
Have you tried using the flashing script directly by running it manually yourself:
sudo ./flash.sh jetson-xavier-nx-devkit mmcblk0p1
Also I am able to recall that issues tend to appear when attempting to flash a Jetson board while working with a virtual machine. It may be worth to browse this forum for related threads to those issues. For example:
Jafet Chaves,
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
ok, i will try. so i don’t have to open the sdk manager? just run it through terminal?
Yes, exactly. You don’t need to open the sdkmanager. You should find this script at: <patch-to-JetPack-install-dir>/Linux_for_Tegra/
Hi eririfky29,
Are you using Xaver NX devkit with eMMC or SD module?
$sudo ./nvsdkmanager_flash.sh --storage nvme0n1p1
Do you connect an NVMe drive and want to flash into it?
For the timeout issue at step3, we would need to check serial console log.
Please refer to the following instruction to capture serial console log.
Jetson Nano & NX Style - Serial Debug Console
i’m using Xavier NX with NVMe, i think it’s devkit with SD module(?)
yes, i choose NVMe for storage device to flash.
ok, i need TTL-USB converter first, so i will give an update later
the solution for me is i install the jetson from SDK manager directly from Linux machine instead of VM. so don’t use VM, it’s not recommended, but certain cases it work.
one of those:
