Not sure if this is the place for this post, but I have seen a lot of posts that try to Flash jetson boards using VMs and sdkmanager but couldn’t find any complete guide. I did this for the 2GB Nano when the etcher method failed for me and I did not have access to a serial device. And after a lot of trial and failure, the process is quite straightforward.
I was never able to successfully flash using Oracle VM VirualBox and it worked first try on VMware. I have linked the community version of VMWare, the one I used for the flash.
- Download and Install VMWare
- Create an Ubuntu 18.04 VM
- Start the VM and in the ‘Player’ dropdown at the top left, go to removable devices.
3.1 If the devices under ‘Removable Devices’ are greyed out
→ Find where the vmx file for your machine is located. You can check this by looking at the ‘Player/Manage/Virtual Machine Settings/Hard Disk’. The vmx file should be in the same folder as the vmdk file.
→ In the vmx file, locate the line,usb.restrictions.defaultAllow = "FALSE"
and delete it - reference. Then restart the virtual machine and you should see the removable devices.
3.2 If the devices under ‘Removable Devices’ are not greyed out, you can move to the next step. - Install sdkmanager and follow the steps there.
- When you connect the board to your machine, ensure that you have followed the steps in the sdkmanager and also that there is a tick alongside your device in
Player/Removable Devices/<Your Device>
- You can also confirm the device is detected by using
lsusb
command.
The following steps should be able to help flash the device. Any comments or improvements welcome.
