Jetson Nx Xavier ./sources_sync.sh
Retrieve the corresponding L4T git tag the kernel source tree
Directory …/linux-4.9-source-tree is present, skipping initialization…
~/linux-4.9-source-tree ~/librealsense
fatal: unable to connect to nv-tegra.nvidia.com:
nv-tegra.nvidia.com[0: 34.216.216.36]: errno=Connection refused
nv-tegra.nvidia.com[1: 35.82.181.43]: errno=Connection refused
The matching L4T source tree tag is
~/librealsense
Create the sandbox - NVidia L4T source tree(s)
Downloading default kernel/kernel-4.9 source…
fatal: repository ‘/home/skivvy/librealsense/Tegra/sources/kernel/kernel-4.9’ does not exist
/home/skivvy/librealsense/Tegra/sources/kernel/kernel-4.9 source sync failed!
Downloading default kernel/nvgpu source…
fatal: repository ‘/home/skivvy/librealsense/Tegra/sources/kernel/nvgpu’ does not exist
/home/skivvy/librealsense/Tegra/sources/kernel/nvgpu source sync failed!
Downloading default kernel/nvidia source…
fatal: repository ‘/home/skivvy/librealsense/Tegra/sources/kernel/nvidia’ does not exist
/home/skivvy/librealsense/Tegra/sources/kernel/nvidia source sync failed!
Downloading default hardware/nvidia/soc/t18x source…
fatal: repository ‘/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/soc/t18x’ does not exist
/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/soc/t18x source sync failed!
Downloading default hardware/nvidia/platform/tegra/common source…
fatal: repository ‘/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/platform/tegra/common’ does not exist
/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/platform/tegra/common source sync failed!
Downloading default hardware/nvidia/platform/t18x/common source…
fatal: repository ‘/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/platform/t18x/common’ does not exist
/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/platform/t18x/common source sync failed!
Downloading default hardware/nvidia/platform/t18x/quill source…
fatal: repository ‘/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/platform/t18x/quill’ does not exist
/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/platform/t18x/quill source sync failed!
Downloading default hardware/nvidia/soc/t210 source…
fatal: repository ‘/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/soc/t210’ does not exist
/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/soc/t210 source sync failed!
Downloading default hardware/nvidia/platform/t210/common source…
fatal: repository ‘/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/platform/t210/common’ does not exist
/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/platform/t210/common source sync failed!
Downloading default hardware/nvidia/platform/t210/jetson source…
fatal: repository ‘/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/platform/t210/jetson’ does not exist
/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/platform/t210/jetson source sync failed!
Downloading default hardware/nvidia/platform/t210/porg source…
fatal: repository ‘/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/platform/t210/porg’ does not exist
/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/platform/t210/porg source sync failed!
Downloading default hardware/nvidia/soc/t19x source…
fatal: repository ‘/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/soc/t19x’ does not exist
/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/soc/t19x source sync failed!
Downloading default hardware/nvidia/platform/t19x/common source…
fatal: repository ‘/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/platform/t19x/common’ does not exist
/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/platform/t19x/common source sync failed!
Downloading default hardware/nvidia/platform/t19x/galen/kernel-dts source…
fatal: repository ‘/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/platform/t19x/galen/kernel-dts’ does not exist
/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/platform/t19x/galen/kernel-dts source sync failed!
Downloading default hardware/nvidia/platform/t19x/jakku/kernel-dts source…
fatal: repository ‘/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/platform/t19x/jakku/kernel-dts’ does not exist
/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/platform/t19x/jakku/kernel-dts source sync failed!
Downloading default hardware/nvidia/soc/tegra source…
fatal: repository ‘/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/soc/tegra’ does not exist
/home/skivvy/librealsense/Tegra/sources/hardware/nvidia/soc/tegra source sync failed!
./Tegra/sources/kernel/kernel-4.9
./scripts/patch-realsense-ubuntu-L4T.sh: line 104: pushd: ./Tegra/sources/kernel/kernel-4.9: No such file or directory
With the current security situation, unfortunately there are a lot of broken services and links.
Our IT teams are investigating to fix that problem.
Sorry for bring the inconvenience.
In the meantime, you can download the source file from each L4T release manually.
See L4T Archive | NVIDIA Developer
Can you provide the installation process?
Pelase refer to NVIDIA Jetson Linux Developer Guide : Kernel Customization | NVIDIA Docs
