Jetson ori argus camera accquire_frame need 66ms delay with imu calibrated, how to reduce this delay?
jetson ori nx argus camera accquire_frame need 66ms delay with imu calibrated, how to reduce this delay?
jetson nx argus need 33ms delay for accquire_frame, why ori nx accquire_frame gets double more delay time?
how to reduce delay for accquire_frame on ori nx?
How do you profile it.
Are the BSP version the same for Orin NX and Xavier NX?
Same software,both use kalibr to calibrate fisheye and imu,it can estimate time offset. Because imu is 200hz, we can think imu as quasi real-time, the result time offset calibrated as: nx’s fisheye is about 33ms delay, and ori nx’s fisheye is about 66ms delay, although with different camera sensor. I think this calibration flow can be verified validly.
BSP versions seems different.
Could you verify on the same version.
