i had issues with an Orin Nano 8GB SOM that refused to boot up.
After some investigation, i figured out, that the SOM runs into an error, that can be observed in the Debug UART and then automatically switches to Force-Recovery mode after some boot-loop attempts.
Here you can see the Debug-Uart log of the SOM during startup and my try to reflash it.
Thanks ~0917
NV team tried to contact you via CRM ticketing system.
Can you check your SPAM box if it is screened.
Once you see if please respond and follow the instruction for next steps.
