When I run this command, I see the logs below but only get a black screen. My camera is the IMX678-MIPI-V2.0. I have two cameras, but I want to connect just one first to check the video output. However, I’m having trouble getting the screen to display.
gst-launch-1.0 nvarguscamerasrc sensor_mode=0 ! ‘video/x-raw(memory:NVMM),width=1280,height=720,framerate=30/1’ ! nvvidconv ! nveglglessink -e
Using winsys: x11
Pipeline is live and does not need PREROLL ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3840 x 2160 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 3840 H = 2160
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadExecute:694 NvBufSurfaceFromFd Failed.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:247 (propagating)
WARNING: from element /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0: Pipeline construction is invalid, please add queues.
Additional debug info:
gstbasesink.c(1209): gst_base_sink_query_latency (): /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0:
Not enough buffering available for the processing deadline of 0:00:00.015000000, add enough queues to buffer 0:00:00.015000000 additional data. Shortening processing latency to 0:00:00.000000000.
Got EOS from element "pipeline0".
Additionally,
cat /etc/nv_tegra_release
# R35 (release), REVISION: 3.1, GCID: 32827747, BOARD: t186ref, EABI: aarch64, DATE: Sun Mar 19 15:19:21 UTC 2023
Based on the provided context, it appears that you are trying to connect a single IMX678 MIPI camera to a Jetson Orin Nano module and display the video output on a screen. However, you are only getting a black screen.
Here are a few potential issues that might be causing the problem:
- Camera configuration: Make sure that the camera is properly configured and recognized by the Jetson Orin Nano module. You can check the camera configuration using the
v4l2-ctl command. For example, you can list all available cameras using v4l2-ctl --list-devices.
- Device tree configuration: The device tree configuration might not be correct for your camera. The device tree configuration is used to describe the hardware components of your system, including the camera. You can check the device tree configuration using the
dtc command. For example, you can dump the device tree configuration using dtc -I fs -O dts /proc/device-tree.
- Camera driver: The camera driver might not be loaded or might not be compatible with your camera. You can check the loaded drivers using the
lsmod command. For example, you can list all loaded drivers using lsmod | grep video.
- Video output: The video output might not be configured correctly. You can check the video output configuration using the
xrandr command. For example, you can list all available video outputs using xrandr --query.
To troubleshoot the issue, you can try the following steps:
- Check the camera configuration using
- Check the device tree configuration using
- Check the loaded drivers using
lsmod | grep video.
- Check the video output configuration using
xrandr --query.
- Try to capture a video using the
v4l2-ctl command. For example, you can capture a video using v4l2-ctl --stream-mmap --stream-count=1 --stream-to=/dev/video0.
If none of these steps help, you can try to provide more information about your system and camera configuration, such as the kernel version, device tree configuration, and camera driver version.
In comparison to other similar issues, such as the one mentioned in the context (Mem copy error - NVMM - DeepStream), the issue you are facing seems to be related to the camera configuration and video output, rather than a memory copy error. However, it’s always a good idea to check the system logs and kernel messages for any error messages that might be related to the issue you are facing.
Confirm the driver and HW by v4l2-ctl is good suggestion.
v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap -d /dev/video0
