Jetson Orin Nano Community Projects
Hi, I find that the projects listed on the following page from my Orin Nano desktop don’t include Orin Nano. Can the Jetson Nano projects be deployed on Orin Nano? Similarly, can Orin NX projects be deployed on Orin Nano?
The Jetson Orin Nano, Jetson Orin NX, and Jetson Nano are all part of the NVIDIA Jetson family, but they have different specifications and capabilities. While it’s technically possible to deploy projects from one device to another, there are some limitations and considerations to keep in mind.
Jetson Nano Projects on Jetson Orin Nano:
The Jetson Nano and Jetson Orin Nano are both based on the NVIDIA Jetson platform, but they have different processors and memory configurations. The Jetson Orin Nano has a more powerful processor and more memory than the Jetson Nano, which means that some projects may not be compatible or may require modifications to run on the Jetson Orin Nano.
That being said, many projects that are designed for the Jetson Nano can be deployed on the Jetson Orin Nano with minimal modifications. The Jetson Orin Nano has a similar architecture and software stack to the Jetson Nano, so many projects can be easily ported over.
However, some projects may require modifications to take advantage of the Jetson Orin Nano’s more powerful processor and additional features. For example, projects that use the Jetson Nano’s limited memory may need to be optimized to run on the Jetson Orin Nano’s more generous memory allocation.
Orin NX Projects on Jetson Orin Nano:
The Jetson Orin NX and Jetson Orin Nano are both part of the Jetson Orin series, but they have different memory configurations and power modes. The Jetson Orin NX has more memory and more powerful processing capabilities than the Jetson Orin Nano, which means that some projects may not be compatible or may require modifications to run on the Jetson Orin Nano.
However, many projects that are designed for the Jetson Orin NX can be deployed on the Jetson Orin Nano with minimal modifications. The Jetson Orin NX and Jetson Orin Nano have similar architectures and software stacks, so many projects can be easily ported over.
That being said, some projects may require modifications to take advantage of the Jetson Orin Nano’s unique features and power modes. For example, projects that use the Jetson Orin NX’s more powerful processing capabilities may need to be optimized to run on the Jetson Orin Nano’s more limited processing capabilities.
Comparison of Jetson Orin Nano, Jetson Orin NX, and Jetson Nano:
Here’s a brief comparison of the Jetson Orin Nano, Jetson Orin NX, and Jetson Nano:
  • Processor: Jetson Orin Nano (Orin CPU), Jetson Orin NX (Orin CPU), Jetson Nano (Quad-core ARM Cortex-A57 CPU)
  • Memory: Jetson Orin Nano (4GB or 8GB LPDDR5), Jetson Orin NX (8GB or 16GB LPDDR5), Jetson Nano (4GB LPDDR4)
  • Power Modes: Jetson Orin Nano (10W, 25W, MAXN SUPER), Jetson Orin NX (10W, 15W, 20W, 40W, MAXN SUPER), Jetson Nano (5W, 10W)
  • Software Stack: Jetson Orin Nano (JetPack 6.2), Jetson Orin NX (JetPack 6.2), Jetson Nano (JetPack 4.6)
In summary, while it’s technically possible to deploy projects from one device to another, there are some limitations and considerations to keep in mind. Many projects can be easily ported over, but some may require modifications to take advantage of the unique features and capabilities of each device.
A shorter answer: The Jetsons have an integrated GPU, an iGPU, not the usual discrete GPU (dGPU) on a PCI bus. The software is less portable due to this, and you would be able to run many of the same things, but only on different releases. The release version issues are the main limitation.
