Jetson Orin NX Module Compatibility with Jetson Orin Nano board
Hi guys, we currently have a Jetson Orin Nano Developer Kit and we wanted to swap out the current module for a Jetson Orin NX 16GB module. Has anyone done this before? Just wanted to confirm the compatibility, thanks!
Hello @et9401,
The pinout of the NVIDIA Jetson Orin Nano and Orin NX is the same,
You should be able to swap the SOM and re-use the carrier board.
We have done it in the past with some of our customers and it works as expected.
Please let us know if you have any other questions or comments.
regards,
Andrew
https://proventusnova.com/embedded-software-engineering-support/
