Carrier Board swapping Chart - Will the Orin NX SOM fit into the Jetson Nano Dev Kit carrier board?
I have a Jetson Nano and it is working well. One of my collogues has a Orin NX SOM. I would like to see if there is an improvement on the task that I am running. Does anyone know if the Nano and the Orin NX are pin for pin compatible?
Hi @rogers_roger,
If you are using the Nano B01 model, you can plug in the Xavier NX and therefore use the Orin NX. However you have to consider power contrains. Check here for more details.
Regards,
Andres
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
