If so, do I need to buy a seperate heatsink for the Orin 16GB NX? and Is there a tutorial video on how to swap the modules?
Hi, @coded7
Yes you can use the Orin Nano carrier with a Orin NX module. The process is just taking the holding screws that hold the SoM to the carrier board and use your fingers to push down the side tabs on the SoM to carrier connector, pretty similar as if you install a memory Sodimm module. Then place the other one at an angle and push down until the tabs click. Then add the screws back to hold it to the carrier.
Regards,
Andres
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
Got it! Thanks!
