你好,我之前是使用Nvidia Orin Nano 8G模組 + 128G SSD 執行專案,最近剛好有Nvidia Orin Nx 16G模組,想請問可以直接將Nano更換成Nx模組執行專案嗎?這樣是否會有問題?
Yes, they’re Pin and form-factor compatible, you can swap to use Orin NX module on the same carrier board.
好的,請問除了8G跟16G的差異之外,功能上會有差異嗎?
Just the system performance will be different as Orin NX is more powerful than Orin Nano, you can find details from Jetson AGX Orin for Next-Gen Robotics | NVIDIA at Technical Specifications section
好的,謝謝。
