Is it possible to get the datasheet for the Wi-Fi antenna used on the Jetson Orin nano? Or at least, how many dBi is the antenna?
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I have moved this post for better visibility.
Cheers,
Tom
The Wi-Fi module is certified for peak gain of 5dBi and our antennas are below 5dBi
Thanks for your answer. Is it possible to get the exact number?
You should assume 5dBi maximum.
