Jetson Orin Nano RTSP
Hello all,
I’m trying to get the camera preview over RTSP on Jetson Orin Nano.
My current setup:
Jetson Orin Nano JP 6.2 in headless mode
gstreamer 1.20
Camera IMX219
I am trying to set-up the camera preview on x86 ubuntu machine connected to Jetson. Camera itself works, checked on the Jetson with RDP.
I am able to get the test image stream by issueing:
On Nano:
./test-launch "videotestsrc is-live=1 ! nvvidconv ! x264enc ! h264parse ! rtph264pay name=pay0 pt=96"
On x86
cvlc rtsp://192.168.137.100:8554/test
Until here everything works fine.
However, I am not sure if my camera preview pipeline is correct. So far I saw couple of examples online, none of them worked. I try:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 sensor-mode=0 ! "video/x-raw(memory:NVMM), format=(string)NV12, framerate=(fraction)10/1" ! nvvidconv  ! queue ! x264enc  ! h264parse ! mpegtsmux ! udpsink host=192.168.137.1 port=5003 sync=0
or
./test-launch “nvarguscamerasrc ! nvvidconv ! x264enc ! h264parse ! rtph264pay name=pay0 pt=96”
but I get :
[rtsp @ 0x7f9288000bc0] method PLAY failed: 454 Session Not Found
rtsp://192.168.137.100:8554/test: Server returned 4XX Client Error, but not one of 40{0,1,3,4}
Could you please help me to construct proper pipeline?
Hi @bkawlatow,
I think it is better if we move this over to the Jetson forum category. I am sure they will be able to help you.
Please try the pipeline in gst-launch-1.0 with fakesink:
$ gst-launch-1.0 nvarguscamerasrc ! nvvidconv !  video/x-raw,format=I420 ! x264enc ! h264parse ! rtph264pay name=pay0 pt=96 ! fakesink
If it runs successfully, please then try
$ ./test-launch "nvarguscamerasrc ! nvvidconv !  video/x-raw,format=I420 ! x264enc ! h264parse ! rtph264pay name=pay0 pt=96"
It works like a charm! The delay is quite significant though, around 4 seconds, do you know maybe how to make it more real time?
If you use rtspsrc plugin to receive the stream, can set latency to 500ms for a try. By default it is 2000ms.
And you can run gst-inspect-1.0 x264enc to check the properties. Certain properties may reduce latency. We don’t have much experience about software encoder and would see if other users can share experience.
