Hi All,
Does Jetson Orin Nano Super support hard coding? I know that Jetson Orin Nano does not support hard coding. I would like to ask if Jetson Orin Nano is also not supported.
Please share what hard coding means. Not quite sure about the query. Please share more information so that we can suggest next.
Hi DaneLLL,
I am currently using Gstreamer to retrieve images from the camera and convert them into H264 streams through soft coding. On Jetson Orin Nano, Gstreamer only has hard decoding plugins and no hard coding plugins, so only soft coding (i.e., CPU coding) can be used for streaming.
I don’t know if I explained it clearly enough for you to understand.
Regrads,
You are right. Orin Nano does not support hardware encoding. It is same with/without enabling super mode.
