Jetson Orin Nano Timeout Crash
Hello everyone,
I am trying to flash Jetson orin nano developer kit with SDK manager. However, at around 90%, the installation is cancelled after giving a timeout error in the waiting target boot section. I tried JetPack 6.2 and JetPack 6.2.1 versions, and I installed a different SSD, the same result. I am sharing the SDK Manager logs in the attachment.
Has anyone had this problem before?
SDKM_logs_JetPack_6.2.1_Linux_for_Jetson_Orin_Nano_[8GB_developer_kit_version]_2025-07-01_13-09-13.zip (1.6 MB)
some questions to confirm:
Is your ubuntu a native or a virtual machine?
I am using native Ubuntu 22.04
Take JP6.2 for example:
Please download Driver Package (BSP) and Sample Root Filesystem from Jetson Linux | NVIDIA Developer.
And follow the Quick Start — NVIDIA Jetson Linux Developer Guide to flash your device.
I tried this method before SDK manager and there was no difference.
Please provide the log and the serial console log.
To record the serial console log, please refer below:
Also make sure your flashing cable support data transfer.
You could change the flashing cable to cross check whether the issue exists.
