Attached log here, could use some guidance on how to proceed. Tried multiple times with different cables.
SDKM_logs_2024-10-24_19-38-02.zip (412.8 KB)
Are you on VM or native Ubuntu 22.04 host PC?
Native ubuntu 22.04 host pc
Hi bharat1031,
Are you using the devkit or custom board for Orin Nano?
19:18:55.752 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Waiting for target to boot-up...
19:18:56.849 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Waiting for target to boot-up...
19:18:57.851 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Timeout
19:18:57.852 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Device failed to boot to the initrd flash kernel. Please retrive the serial log during flashing to debug further.
19:18:57.852 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Cleaning up...
It seems you have timeout issue in Step 3 during flash.
Normally, it is caused by boot issue on your board. Please share the serial console log at this moment for further check.
