Jetson Orin NX 16GB (JP5.1.1) Fails to Boot with UEFI Stuck, OP-TEE Warnings in Log (Recovered after 4th Reset)
Device: NVIDIA Jetson Orin NX 16GB (Custom board)
JetPack Version: 5.1.1
Behavior:
  • The device worked normally for 2 months.
  • Suddenly failed to boot (stuck at UEFI stage) after no configuration changes.
  • Required 3 forced resets (no success), but booted successfully on the 4th attempt.
  • Captured serial logs show OP-TEE warnings and secure boot-related errors.
    The debug log is as follows:
    MobaXterm_COM3USB-SERIALCH340COM3_20250424_140402.txt (16.4 KB)
What could be the possible reason for the occurrence of this phenomenon?
hello waylo,
it’s crucial what’s the modification you’ve done, or, did you have firmware updates?
are you able to interrupt the UEFI for entering the UEFI menu?
  • No configuration changes were made prior to the issue.
  • The device is deployed in a vehicle for analyzing captured video footage.
  • All services and programs are configured for auto-start. Field operators have no permissions to modify the system.
  • The only operations performed are:
    • Powering on the device by supplying electricity.
    • Powering it off by cutting the power supply.
Additional Notes:
  • The device has never received firmware updates since deployment.
  • During this incident:
    • No operations could be performed via the debug serial port.
    • The UEFI stage could not be interrupted (e.g., no access to UEFI settings or boot menu).
hello waylo,
due to it’s stuck in UEFI, you may need to enable UEFI debug logs for understand the root cause.
could you please refer to Home · NVIDIA/edk2-nvidia Wiki · GitHub to rebuild/update UEFI binary with debug favor for more details.
