My Orin Nano ( original, not custom board ) won’t boot and won’t even display anything on screen, not even the Nvidia logo on startup. I don’t have an Ubuntu computer so I am unable to use SDK Manager. I am using Jetpack 5 because I need Ubuntu 20. I tried reflashing the SD Card with BalenaEtcher but nothing changes. Here are the logs I got from UART Debug.
orin hata.txt (33.8 KB)
Last lines of it:
▒▒NOTICE: BL31: v2.6(release):cec9a2bc3
NOTICE: BL31: Built : 20:07:12, Jun 13 2024
I/TC: Physical secure memory base 0x27c040000 size 0x3fc0000
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.22 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Fri Jun 14 03:16:24 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version 5.0-36585864 built on 2024-06-14T03:08:10+00:00)
▒▒I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
ASSERT [FvbNorFlashStandaloneMm] /dvs/git/dirty/git-master_linux/out/nvidia/optee.t234-uefi/StandaloneMmOptee_RELEASE/edk2-nvidia/Silicon/NVIDIA/Drivers/FvbNorFlashDxe/FvbNorFlashStandaloneMm.c(978): ((BOOLEAN)(0==1))
