Jetson Orin Nano Dev kit booting issue
log.txt (36.4 KB)
Jetson Orin Nano Dev Kit booting stop as below message:
��NOTICE: BL31: v2.8(release):e12e3fa93
NOTICE: BL31: Built : 09:56:21, May 6 2024
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.22 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Mon May 6 17:07:49 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check Porting guidelines — OP-TEE documentation documentation
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version 36.3.0-gcid-36191598 built on 2024-05-06T16:58:59+00:00)
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
I/TC: WARNING: Test UEFI variable auth key is being used !
I/TC: WARNING: UEFI variable protection is not fully enabled !
ASSERT [FvbNorFlashStandaloneMm] /out/nvidia/optee.t234-uefi/StandaloneMmOptee_RELEASE/edk2-nvidia/Silicon/NVID)
Is this a DevKit or a custom board?
How did you flash the device? Has it ever been working before?
  1. This is not a custom board.
  2. It was working before flashing the device.
  3. I flashed the device using an image and SDK manager, but the SDK manager always fails.
Did the flashing process succeed, but just that it fails to boot up afterwards, or even the flashing process itself fail?
  1. Flashing the image via BalenaEtcher succeeded, but booting failed.
  2. Flashing with SDK Manager failed. Log is attached.
SDKM_logs_JetPack_6.0_(rev._2)_Linux_for_Jetson_Orin_Nano_modules_2024-06-27_17-11-48.zip (255.1 KB)
TO me , it seems same issue what I got as mentioned on Again Display flicking Issue popped up , upgraded to Jetpack6.0GA but still issue persists . Reflashing Jetpack via SDK manager worked for me.
17:26:27.645 - Info: mount.nfs: Connection timed out
17:26:27.649 - Info: Flash failure
17:26:27.652 - Info: Either the device cannot mount the NFS server on the host or a flash command has failed. Debug log saved to /tmp/tmp.9pTyWhvC7F. You can access the target's terminal through "sshpass -p root ssh root@fc00:1:1:0::2"
Check your firewall setting, or get another USB cable and try again.
