Dear all:
1: Orin NX SOM + customed board(p3509), + JP5.1.2, mcp2515 can send data, can not recieve data.
XAVER NX SOM + costomed board(p3509) +JP5.1,2, mcp2515 can send data, can not recieve data.
XAVIER NX SOM + customed board(p3509) + JP4.6, mcp2515 can send data, can recieve data.
In JP4.6, I change tegra19x-mb1-pinmux-p3668-a01.cfg as follow.
pinmux.0x0243d040 = 0x00000444;
pinmux.0x0243d020 = 0x00000444;
pinmux.0x0243d058 = 0x00000444;
pinmux.0x0243d010 = 0x00000448;
--- a/hardware/nvidia/platform/t19x/jakku/kernel-dts/common/tegra194-p3668-common.dtsi
+++ b/hardware/nvidia/platform/t19x/jakku/kernel-dts/common/tegra194-p3668-common.dtsi
@@ -464,12 +466,22 @@
status = "okay";
+ can_clock: can_clock {
+ compatible = "fixed-clock";
+ #clock-cells = <0>;
+ clock-frequency = <8000000>;
+ clock-accuracy = <100>;
spi@3210000{ /* SPI1 in 40 pin conn */
status = "okay";
spi@0 { /* chip select 0 */
- compatible = "tegra-spidev";
+ compatible = "microchip,mcp2515";
reg = <0x0>;
- spi-max-frequency = <50000000>;
+ spi-max-frequency = <5000000>;
+ interrupt-parent = <&tegra_main_gpio>;
+ interrupts = <TEGRA194_MAIN_GPIO(Q, 5) 0x0>;
+ clocks = <&can_clock>;
controller-data {
nvidia,enable-hw-based-cs;
2: for Orin NX with JP5.1.2
+++ b/hardware/nvidia/platform/t23x/p3768/kernel-dts/cvb/tegra234-p3509-a02.dtsi
@@ -135,14 +135,26 @@
nvidia,xusb-padctl = <&xusb_padctl>;
status = "okay";
reg = <0x0>;
+ spi-max-frequency = <200000>;
+ nvidia,rx-clk-tap-delay = <0x7>;
+ interrupts = <TEGRA234_MAIN_GPIO(Q, 5) GPIO_ACTIVE_LOW>;
+ nvidia,enable-hw-based-cs;
tegra234-mb1-bct-gpioint-p3767-0000.dts 2023-08-17 16:41:32.113385966 +0800
@@ -181,11 +181,6 @@
pin-0-int-line = <0>; // GPIO Z0 to INT0
pin-1-int-line = <0>; // GPIO Z1 to INT0
pin-2-int-line = <0>; // GPIO Z2 to INT0
- pin-3-int-line = <0>; // GPIO Z3 to INT0
- pin-4-int-line = <0>; // GPIO Z4 to INT0
- pin-5-int-line = <0>; // GPIO Z5 to INT0
- pin-6-int-line = <0>; // GPIO Z6 to INT0
- pin-7-int-line = <0>; // GPIO Z7 to INT0
tegra234-mb1-bct-pinmux-p3767-hdmi-a03.dtsi 2023-08-25 16:18:30.619419302 +0800
@@ -731,18 +731,18 @@
spi1_sck_pz3 {
nvidia,pins = "spi1_sck_pz3";
- nvidia,function = "rsvd1";
- nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
- nvidia,tristate = <TEGRA_PIN_ENABLE>;
- nvidia,enable-input = <TEGRA_PIN_ENABLE>;
+ nvidia,function = "spi1";
+ nvidia,pull = <TEGRA_PIN_PULL_NONE>;
+ nvidia,tristate = <TEGRA_PIN_DISABLE>;
+ nvidia,enable-input = <TEGRA_PIN_DISABLE>;
nvidia,io-high-voltage = <TEGRA_PIN_DISABLE>;
nvidia,lpdr = <TEGRA_PIN_DISABLE>;
spi1_miso_pz4 {
nvidia,pins = "spi1_miso_pz4";
@@ -751,20 +751,20 @@
spi1_mosi_pz5 {
nvidia,pins = "spi1_mosi_pz5";
spi1_cs0_pz6 {
nvidia,pins = "spi1_cs0_pz6";
- nvidia,pull = <TEGRA_PIN_PULL_UP>;
After insmod mcp251x.ko, but can1 just can send data, can not recieve data.
Thank you very much. Best Regards to all.
