I am trying debug jetson-rdma-picoevb(rel-36+) on jetson orin nx.The FPGA is connected to NX with PCIe(0007:01:00.0). After executing rdma-cuda-c2h-perf, I saved the buf from the cudaHostAlloc . A total of 64k data is transferred, but some data is not transferred each time. The attachment is the data I saved, for example, the offset position is 0x2020 there is 2K data that has not been updated; The offset position is 0x4820 there are 32 bytes of data that have not been updated. I suspect that I need to perform a flush operation for the cache after the PCIe transfer is complete?What should I do if I need to?
output_binary_file0.zip (290 Bytes)
Could you give the flush a try to see if it fixes the issue?
I’ve tried two flush cache methods, but to no avail.
1,flush_cache_all(); The results have not changed, and some of the address data has not been updated.
2,dma_sync_single_for_cpu(pevb->dev, dst->dmas[0].addr, dst->dmas[0].len, DMA_FROM_DEVICE); After the API is called, the system suspends and restarts.
Problem solved, FPGA transfer problem, sorry for wasting your time.
