Jetson TX2 connect to external non- volatile memory board
Hi, we would like to use JETSON TX2 to connect to an emerging memory externally using a carrier board. The memory chip on the carrier board is used as a traditional DRAM. Could someone help to see if the following solution is feasible?
For example, this is an EasyPCI universal carrier board. The carrier board connects to Jetson TX2 using a USB.
Hi, from hardware side, it is standard USB port on Jetson TX2. You can use that for a USB device.
