Jetson TX2 External eMMC Support
I would like to use external eMMC memory for my application. The TX2 datasheet mentions the SD/eMMC controller supports eMMC 5.1, but it is unclear whether the SDMMC1 interface at the module connector supports this.
Can SDMMC1 be used to interface with external eMMC in 4-bit mode? Or does SDMMC1 only support SD card/SDIO?
Only SDIO or SD card supported on the port.
