Jetson TX2 supported camera resolution
I am planning to use the NVIDIA Jetson TX2 board to acquire high quality image. One of the camera I would like to use with this board is the SONY IMX318.
The maximal resolution of this camera is 5448 x 4112 and it’s has a CSI-2 serial data output, MIPI-C/D-PHY. Is that compatible with the TX2 board? If so, is there some specifics drivers for this kind of cameras?
Here is the IMX 318 documentation.
https://www.sony-semicon.co.jp/products_en/IS/sensor1/img/products/ProductBrief_IMX318_20161122.pdf
Regards,
Sébastien
Yes, TX2 can support this kind of sensor but maybe next release BSP.
OK, thanks for your reply. Then for now I’ll start with a lower resolution sensor, as I don’t get enough information from the SONY IMX 318 datasheet to write the driver.
Sebastien, do you have a camera or a board solution you’re going to use with this sensor?
