i use Jetson Xavier AGX on custom carrier. The usb port 1 does not use the pd controller and is host only (type A). I disabled it on devicetree but the usb does not work. Note that the VBUS is always power on. I don’t find example on Tegra_Linux_Driver_Package_AGX_Xavier_Adaptation_Guide.pdf. Do you have device-tree example for this application?
Just assign dummy regulator(battery_reg) to the vbus supply.
BTW, this is NX forum but not AGX forum. You filed on the wrong one. Your answer could be found on the AGX forum.
This is not a new issue here.
Solve it using Jetson/FAQ/BSP/Remove TypeC - eLinux.org
