Jetson Xavier AGX RTSP input
Jetson Xavier AGX
Jetpack 4.5.1
Deepstream 5.1
I’m having a problem connecting my deepstream-app to my RTSP server cam. Deepstream-app opens successfully yet the screen only shows a black screen. Please see my config file below. I can see the stream on VLC Player but not with the app. The issue might be the video decoder. Any help will be appreciated.
Config file;
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable = 0
rows = 1
columns = 1
width = 1920
height = 1080
gpu-id = 0
nvbuf-memory-type = 0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=4
uri=rtsp://admin:admin@172.16.1.118:554
num-sources=1
#drop-frame-interval=2
gpu-id=0
# (0): memtype_device   - Memory type Device
# (1): memtype_pinned   - Memory type Host Pinned
# (2): memtype_unified  - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=2
source-id = 0
gpu-id = 0
sync=0
[osd]
enable = 1
gpu-id = 0
border-width = 1
text-size = 15
text-color = 1;1;1;1;
text-bg-color = 0.3;0.3;0.3;1
font = Arial
show-clock = 0
clock-x-offset = 800
clock-y-offset = 820
clock-text-size = 12
clock-color = 1;0;0;0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=1
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable = 1
gpu-id = 0
bbox-border-color0 = 1;0;0;1
bbox-border-color1 = 0;1;1;1
bbox-border-color2 = 0;0;1;1
bbox-border-color3 = 0;1;0;1
interval = 2
gie-unique-id = 1
int8-calib-file = …/…/…/…/…/samples/models/Resnet18_Face_Detection/calibration.bin
labelfile-path = …/…/…/…/…/samples/models/Resnet18_Face_Detection/labels.txt
tlt-encoded-model = …/…/…/…/…/samples/models/Resnet18_Face_Detection/resnet18_detector.etlt
tlt-model-key = M3Uyam5hcmQzMWRvaG1jNHFhbGJyamoyaTE6MzE5NTYwMzMtNTUyZS00ZTU0LWFhZGUtNzFhM2EyOWEyMDQ0
config-file = …/…/…/…/…/samples/configs/deepstream-app/config_infer_face_primary.txt
batch-size = 1
[tracker]
enable = 0
tracker-width = 640
tracker-height = 384
ll-lib-file = /opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
gpu-id = 0
enable-batch-process = 0
[tests]
file-loop=0
Please check if the URI is playable through uridecodebin:
$ gst-launch-1.0 uridecodebin uri=rtsp://admin:admin@172.16.1.118:554 ! nvoverlaysink
Stuck in this screen.
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://admin:admin@172.16.1.118:554
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
Progress: (request) SETUP stream 1
Progress: (open) Opened Stream
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Progress: (request) Sending PLAY request
Progress: (request) Sent PLAY request
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Looks like video decoding is running from the log. Do you see video playback on screen?
@DaneLLL No, I do not.
Please try Jetpack 4.6.1(r32.7.1) and check if the RTSP input can be decoded.
