Could you please confirm and help on these?
1) Jetson Xavier uses Tegra architecture (??)
In tegra devices CPU and GPU (iGPU) share the SoC DRAM memory
2) If the first statement is correct:
Since Cuda applications require modifications to perform efficiently on Tegra systems, because of the unified memory, Cuda codes for Jetson Xavier should also be modified for better performance.
nvcc version on my Xavier is : “Cuda compilation tools, release 10.2, V10.2.89”
Hence checking Cuda for Tegra, applications notes, DA-06762-001_v10.2, page 7 sample code
In the sample code of the document, cudaMallocManaged used, instead of standard cudaMalloc, for unified memory allocation. And also no kind of cudaMemcpy used. So i expect to see similar modifications for cuda codes for Tegra devices.
3) But when i check the “/usr/local/cuda/samples/0_Simple” folder in the Xavier and investigate the matrixMul.cu code, doesn’t really look like modified. Code looks like as if written for a discrete GPU
* Run a simple test of matrix multiplication using CUDA
int MatrixMultiply(int argc, char **argv,
int block_size, const dim3 &dimsA,
const dim3 &dimsB) {
// Allocate host memory for matrices A and B
unsigned int size_A = dimsA.x * dimsA.y;
unsigned int mem_size_A = sizeof(float) * size_A;
float *h_A = reinterpret_cast<float *>(malloc(mem_size_A));
unsigned int size_B = dimsB.x * dimsB.y;
unsigned int mem_size_B = sizeof(float) * size_B;
float *h_B = reinterpret_cast<float *>(malloc(mem_size_B));
cudaStream_t stream;
// Initialize host memory
const float valB = 0.01f;
ConstantInit(h_A, size_A, 1.0f);
ConstantInit(h_B, size_B, valB);
// Allocate device memory
float *d_A, *d_B, *d_C;
// Allocate host matrix C
dim3 dimsC(dimsB.x, dimsA.y, 1);
unsigned int mem_size_C = dimsC.x * dimsC.y * sizeof(float);
float *h_C = reinterpret_cast<float *>(malloc(mem_size_C));
if (h_C == NULL) {
fprintf(stderr, "Failed to allocate host matrix C!\n");
exit(EXIT_FAILURE);
checkCudaErrors(cudaMalloc(reinterpret_cast<void **>(&d_A), mem_size_A));
checkCudaErrors(cudaMalloc(reinterpret_cast<void **>(&d_B), mem_size_B));
checkCudaErrors(cudaMalloc(reinterpret_cast<void **>(&d_C), mem_size_C));
// Allocate CUDA events that we'll use for timing
cudaEvent_t start, stop;
checkCudaErrors(cudaEventCreate(&start));
checkCudaErrors(cudaEventCreate(&stop));
checkCudaErrors(cudaStreamCreateWithFlags(&stream, cudaStreamNonBlocking));
// copy host memory to device
checkCudaErrors(cudaMemcpyAsync(d_A, h_A, mem_size_A, cudaMemcpyHostToDevice, stream));
checkCudaErrors(cudaMemcpyAsync(d_B, h_B, mem_size_B, cudaMemcpyHostToDevice, stream));
// Setup execution parameters
dim3 threads(block_size, block_size);
dim3 grid(dimsB.x / threads.x, dimsA.y / threads.y);
// Create and start timer
printf("Computing result using CUDA Kernel...\n");
// Performs warmup operation using matrixMul CUDA kernel
if (block_size == 16) {
MatrixMulCUDA<16> <<< grid, threads, 0, stream>>>(d_C, d_A, d_B,
dimsA.x, dimsB.x);
} else {
MatrixMulCUDA<32> <<< grid, threads, 0, stream>>>(d_C, d_A, d_B,
dimsA.x, dimsB.x);
printf("done\n");
checkCudaErrors(cudaStreamSynchronize(stream));
// Record the start event
checkCudaErrors(cudaEventRecord(start, stream));
// Execute the kernel
int nIter = 300;
for (int j = 0; j < nIter; j++) {
MatrixMulCUDA<16> <<<grid, threads, 0, stream>>>(d_C, d_A, d_B,
dimsA.x, dimsB.x);
} else {
MatrixMulCUDA<32> <<<grid, threads, 0, stream>>>(d_C, d_A, d_B,
dimsA.x, dimsB.x);
// Record the stop event
checkCudaErrors(cudaEventRecord(stop, stream));
// Wait for the stop event to complete
checkCudaErrors(cudaEventSynchronize(stop));
float msecTotal = 0.0f;
checkCudaErrors(cudaEventElapsedTime(&msecTotal, start, stop));
// Compute and print the performance
float msecPerMatrixMul = msecTotal / nIter;
double flopsPerMatrixMul = 2.0 * static_cast<double>(dimsA.x) *
static_cast<double>(dimsA.y) *
static_cast<double>(dimsB.x);
double gigaFlops = (flopsPerMatrixMul * 1.0e-9f) /
(msecPerMatrixMul / 1000.0f);
printf(
"Performance= %.2f GFlop/s, Time= %.3f msec, Size= %.0f Ops," \
" WorkgroupSize= %u threads/block\n",
gigaFlops,
msecPerMatrixMul,
flopsPerMatrixMul,
threads.x * threads.y);
// Copy result from device to host
checkCudaErrors(cudaMemcpyAsync(h_C, d_C, mem_size_C, cudaMemcpyDeviceToHost, stream));
printf("Checking computed result for correctness: ");
bool correct = true;
// test relative error by the formula
// |<x, y>_cpu - <x,y>_gpu|/<|x|, |y|> < eps
double eps = 1.e-6; // machine zero
for (int i = 0; i < static_cast<int>(dimsC.x * dimsC.y); i++) {
double abs_err = fabs(h_C[i] - (dimsA.x * valB));
double dot_length = dimsA.x;
double abs_val = fabs(h_C[i]);
double rel_err = abs_err / abs_val / dot_length;
if (rel_err > eps) {
printf("Error! Matrix[%05d]=%.8f, ref=%.8f error term is > %E\n",
i, h_C[i], dimsA.x * valB, eps);
correct = false;
printf("%s\n", correct ? "Result = PASS" : "Result = FAIL");
// Clean up memory
free(h_A);
free(h_B);
free(h_C);
checkCudaErrors(cudaFree(d_A));
checkCudaErrors(cudaFree(d_B));
checkCudaErrors(cudaFree(d_C));
checkCudaErrors(cudaEventDestroy(start));
checkCudaErrors(cudaEventDestroy(stop));
printf("\nNOTE: The CUDA Samples are not meant for performance"\
"measurements. Results may vary when GPU Boost is enabled.\n");
if (correct) {
return EXIT_SUCCESS;
} else {
return EXIT_FAILURE;
For Jetson Xavier, should I write my codes as in /usr/local/cuda/samples/0_Simple/MatrxiMul.cu example or stick with Cuda for Tegra Application notes? What you do you suggest?
