Jetson Xavier NX Booting fail
hello
While running using Jetson Xavier NX module
After power off & power on, there is a symptom of not booting.
The debug log is attached as below.
It fails to boot and continues into recovery mode.
I see Thermal config & MEMIO rail config Fail message, what does it mean?
Attempting to flash the module again fails…
Can you tell me what could be the problem?
[0000.025] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.034] I> MB1 (prd-version: 1.5.1.7-t194-41334769-98030a79)
[0000.039] I> Boot-mode: Coldboot
[0000.042] I> Chip revision : A02P
[0000.045] I> Bootrom patch version : 15 (correctly patched)
[0000.050] I> ATE fuse revision : 0x200
[0000.054] I> Ram repair fuse : 0x0
[0000.057] I> Ram Code : 0x1
[0000.059] I> rst_source: 0x0
[0000.062] I> rst_level : 0x0
[0000.066] I> Boot-device: QSPI
[0000.068] I> Qspi flash params source = brbct
[0000.072] I> Qspi using bpmp-dma
[0000.075] I> Qspi clock source : pllp
[0000.079] I> QSPI Flash Size = 32 MB
[0000.082] I> Qspi initialized successfully
[0000.086] W> No valid slot number is found in scratch register
[0000.092] W> Return default slot: _a
[0000.095] I> Active Boot chain : 0
[0000.098] I> Boot-device: QSPI
[0000.101] I> Qspi flash params source = brbct
[0000.107] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.114] I>Temperature = 45500
[0000.117] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.122] W> Skipping boost for clk: BPMP_APB
[0000.126] W> Skipping boost for clk: AXI_CBB
[0000.130] W> Skipping boost for clk: AON_CPU_NIC
[0000.134] W> Skipping boost for clk: CAN1
[0000.138] W> Skipping boost for clk: CAN2
[0000.142] I> Boot-device: QSPI
[0000.145] I> Boot-device: QSPI
[0000.147] I> Qspi flash params source = mb1bct
[0000.152] I> Qspi using bpmp-dma
[0000.155] I> Qspi clock source : pllc_out0
[0000.158] I> Qspi reinitialized
[0000.161] I> Qspi flash params source = mb1bct
[0000.167] I> ECC region[0]: Start:0x0, End:0x0
[0000.171] I> ECC region[1]: Start:0x0, End:0x0
[0000.175] I> ECC region[2]: Start:0x0, End:0x0
[0000.179] I> ECC region[3]: Start:0x0, End:0x0
[0000.183] I> ECC region[4]: Start:0x0, End:0x0
[0000.187] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.193] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.198] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.202] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.206] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.212] E> FAILED: Thermal config
[0000.219] E> FAILED: MEMIO rail config
[0000.229] E> Task 50 failed (err: 0x7979061c)
[0000.233] E> Top caller module: ALIASCHECKER, error module: ALIASCHECKER, reason: 0x1c, aux_info: 0x06
[0000.242] I> MB1 (1.5.1.7-t194-41334769-98030a79) BIT boot status dump :
0000000000011111111110111111111111111111111100111110000000000000000000000000000000000000000000000000000000000000000000000000000 0000
000110110000000000000000000000000000
Are you using devkit carrier board or with your custom carrier board?
Which JetPack you’re using?
Which Xavier NX module you’re using? with eMMC?
I’m using a custom carrier board, and I’m using Jetpack 4.6 version.
The flash is on the emmc and is an 8G module.
Hi JinSH,
Could you help to flash latest JP4.6.3(R32.7.3) to verify?
Could your board boot up before?
Do you have any flash log from your host side for further check?
sorry for the late reply
No matter which jetpack you download, the symptoms are the same…
I am attaching the host log for downloading version 4.6.3, so please check it.
Thank you
SDKM_logs_JetPack_4.6.3_Linux_for_Jetson_Xavier_NX_modules_2023-06-29_16-00-00.zip (123.4 KB)
16:12:16.634 - info: Event: Device APX was unplugged from usb port.
16:12:16.702 - error: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS: Failed flashing t186ref.
16:12:16.702 - info: Event: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS - error is: Failed flashing t186ref.
Are you using the standalone Ubuntu 18.04 or 20.04 as your host PC for SDKM?
Please make sure your USB connection during flash or just change another port or cable.
