[14:19:06.087]收←◆\0
[14:19:06.456]收←◆\0?
[0000.084] I> MB1 (prd-version: 1.1.0.0-t194-41334769
[14:19:06.509]收←◆-514a1108)
[0000.090] I> Boot-mode: L0 coldboot
[0000.093] I> Chip revision : A02P
[0000.096] I> Bootrom patch version : 15 (correctly patched)
[0000.101] I> ATE fuse revision : 0x200
[0000.105] I> Ram repair fuse : 0x0
[0000.108] I> Ram Code : 0x2
[0000.110] I> rst_source : 0x0
[0000.113] I> rst_level : 0x0
[0000.116] I> Boot-device: eMMC
[0000.119] W> DEVICE_PROD: device prod is not initialized.
[0000.124] W> DEVICE_PROD: device prod is not initialized.
[000
[14:19:06.685]收←◆0.141] I> sdmmc DDR50 mode
[0000.145] W> DEVICE_PROD: device prod is not initialized.
[0000.151] W> No valid slot number is found in scratch register
[0000.156] W> Return default slot: _a
[0000.159] I> Active Boot chain : 0
[0000.162] I> Boot-device: eMMC
[0000.166] E> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.172] E> MB1_PLATFORM_CONFIG: Failed to initialize device prod.
[0000.180] I> Temperature = 33500
[0000.183] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.187] W> Skipping boost for clk: BPMP_APB
[0000.191] W> Skipping boost for clk: AXI_CBB
[0000.195] W> Skipping boost for clk: AON_CPU_NIC
[0000.199] W> Skipping boost for clk: CAN1
[0000.203] W> Skipping boost for clk: CAN2
[0000.207] I> Boot-device: eMMC
[0000.210] I> Boot-device: eMMC
[0000.220] I> Sdmmc: HS400 mode enabled
[0000.228] I> ECC region[0]: Start:0x0, End:0x0
[0000.232] I> ECC region[1]: Start:0x0, End:0x0
[0000.236] I> ECC region[2]: Start:0x0, End:0x0
[0000.240] I> ECC region[3]: Start:0x0, End:0x0
[0000.244] I> ECC region[4]: Start:0x0, End:0x0
[0000.248] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.254] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.258] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.263] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.267] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.273] W> MB1_PLATFORM_CONFIG: Rail ID 9 not found in pmic rail config table.
[0000.280] E> FAILED: Thermal config
[0000.283] W> DEVICE_PROD: device prod is not initialized.
[0000.288] W> DEVICE_PROD: device prod is not initialized.
[0000.297] W> MB1_PLATFORM_CONFIG: Rail ID 7 not found in pmic rail config table.
[0000.304] E> FAILED: MEMIO rail config
[14:19:06.713]收←◆[0000.325] I> scrub mode: full dram
[0000.328] E> FUSE: Failed to verify ECID.
[0000.343] I> sdmmc bdev is already
[14:19:06.728]收←◆initialized
[14:19:06.760]收←◆[0000.379] W> No fuse-bypass data
