Xavier boot and flash problem
hello
I have a problem with my xavier carrier board. when boot with normal mode ,there no signal in debug uart.
when boot with recovery mode , the device-mode is wrong.emmc is correct.
[0023.231] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0023.240] I> MB1 (prd-version: 1.5.1.2-t194-41334769-9ec1833d)
[0023.245] I> Boot-mode: Platform RCM
[0023.248] I> Chip revision : A02P
[0023.251] I> Bootrom patch version : 15 (correctly patched)
[0023.257] I> ATE fuse revision : 0x200
[0023.260] I> Ram repair fuse : 0x0
[0023.263] I> Ram Code : 0x2
[0023.266] I> rst_source : 0x0
[0023.268] I> rst_devel : 0x0
[0023.272] I> USB configuration success
[0025.473] I> mb2 image downloaded
[0025.576] I> Recovery boot mode 0
[0025.587] I> Boot-device: SATA
[0025.591] I> UPHY full init done
[0025.596] I> MB1 done
[0025.601] W> Profiler not initialized
[0025.604] I> Welcome to MB2(TBoot-BPMP) Applet (version: 00.00.2018.32-mobile%2cd5f333)
[0025.612] W> Profiler not initialized
[0025.615] I> DMA Heap @ [0x40020000 - 0x40065800]
[0025.620] I> Default Heap @ [0xd486400 - 0xd48a400]
[0025.625] W> Profiler not initialized
[0025.628] W> @rofiler not initialized
[0025.632] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0025.637] W> device prod register failed
[0025.641] W> Profiler not initialized
[0025.703] I> sdmmc DDR50 mode
[0025.707] I> No supported QSPI flash found
[0025.711] E> QSPI Flash: Insufficient flash size (0 MB)
[0025.716] I> QSPI Flash is not present.
[0025.767] E> Link startup dme_set failed
[0025.771] E> UFS initialization failed
[0025.775] I> UFS is not present
[0025.778] W> Profiler not initialized
[0025.784] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0025.793] I> Found 42 partitions in SDMMC_USER (instance 3)
[0025.798] W> Profiler not initialized
[0025.801] W> Profiler not initialized
[0025.805] W> Profiler not initialized
[0025.808] I> Entering 3p server
[0025.812] I> USB configuration success
[0026.853] I> Populate eeprom info
K0026.859] I> Populate eeprom info for module cvm
[0032.070] I> Rebooting : reboot-recovery
[003
 [0027.097] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0027.105] I> MB1 (prd-version: 1.5.1.2-t194-41334769-9ec1833d)
[0027.111] I> Boot-mode: RCM
[0027.113] I> Chip revision : A02P
[0027.116] I> Bootrom patch version : 15 (correctly patched)
[0027.122] I> ATE fuse revision : 0x200
[0027.125] I> Ram repair fuse : 0x0
[0027.128] I> Ram Code : 0x2
[0027.131] I> rst_source : 0xb
[0027.133] I> rst_level : 0x1
[0027.137] I> USB configuration success
[0035.430] I> bct_bootrom image downloaded
[0035.451] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0035.459] I> Temperature = 34500
[0035.462] W> Skipping boost for clk: BPMP_CPU_NIC
[0035.466] W> Skipping boost for clk: BPMP_APB
[0035.470] W> Skipping boost for clk: AXI_CBB
[0035.474] W> Skipping boost for clk: AON_CPU_NIC
[0035.478] W> Skipping boost for clk: CAN1
[0035.482] W> Skipping boost for clk: CAN2
[0035.487] I> Boot-device: SATA
[0035.489] I> Boot-device: SATA
[0035.492] W> MB1_PLATFORM_CONFIG: Module 25.0 not found in device config table.
[0035.499] I> Sata params source = safe params
[0035.503] I> bct_mb1 image downloaded
[0035.526] I> ECC region[0]: Start:0x0, End:0x0
[0035.530] I> ECC region[1]: Start:0x0, End:0x0
[0035.534] I> ECC region[2]: Start:0x0, End:0x0
[0035.538] I> ECC region[3]: Start:0x0, End:0x0
[0035.542] I> ECC region[4]: Start:0x0, End:0x0
[0035.546] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0035.552] I> Non-ECC region[1]: Start:0x0, End:0x0
[0035.557] I> Non-ECC region[2]: Start:0x0, End:0x0
[0035.561] I> Non-ECC region[3]: Start:0x0, End:0x0
[0035.566] I> Non-ECC region[4]: Start:0x0, End:0x0
[0035.572] E> FAILED: Thermal config
[0035.579] E> FAILED: MEMIO rail config
[0035.598] I> bct_mem image downloaded
[0037.812] I> blob image downloaded
[0037.884] I> Recovery boot mode 0
[0037.951] I> MB1 done
In a normal boot, there should be login prompts on the two “real” UARTs. You should be able to get to one of them from the RasPi connector using a TTL-to-USB converted.
It says:
Boot-device: SATA
Is it possible to boot MB2 from a SATA device? How?
Best,
Mustafa Güler
Hi mustafa.gueler,
Please help to open a new topic if it’s still an issue to support.
No thanks!
