Jetson AGX Xavier Industrial OS Flashing & Bootup issue
Custom carrier board Jetson AGX Xavier Industrial OS not Flashing & Bootup
Error log captured in the UART3 port below.
[0015.671] W> RATCHET: MB1 binary ratchet value 4 is larger than ratchet level 2 from HW fuses.
[0015.679] I> MB1 (prd-version: 2.5.0.0-t194-41334769-d9272b5a)
[0015.684] I> Boot-mode: Platform RCM
[0015.688] I> Platform: Silicon
[0015.691] I> Chip revision : A02P
[0015.694] I> Bootrom patch version : 15 (correctly patched)
[0015.699] I> ATE fuse revision : 0x200
[0015.702] I> Ram repair fuse : 0x0
[0015.705] I> Ram Code : 0x1
[0015.708] I> rst_source: 0x0, rst_level: 0x0
[0015.713] I> USB configuration success
[0017.856] I> mb2 image downloaded
[0017.941] I> Recovery boot mode 0
[0017.947] I> UPHY full init done
[0017.954] I> MB1 done
[0017.959] I> Welcome to MB2(TBoot-BPMP) Applet (version: default.t194-mobile-4ae695b2)
[0017.966] I> DMA Heap @ [0x40020000 - 0x40065800]
[0017.971] I> Default Heap @ [0xd486400 - 0xd48a400]
[0017.975] W> Profiler not initialized
[0017.994] I> sdmmc DDR50 mode
[0017.997] I> QSPI-0l initialized successfully
[0018.004] E> CLK_RST: instance 6 not found in module 44.
[0018.009] E> MPhy CAR configuration failed error = 1747992077
[0018.015] E> UFS initialization failed
[0018.018] I> UFS is not present
[0018.022] W> Cannot find any partition table for 00000003
[0018.028] > PARTITION_MANAGER: Failed to publish partition.
[0018.034] W> Cannot find any partition table for 00010003
[0018.039] > PARTITION_MANAGER: Failed to publish partition.
[0018.045] W> Cannot find any partition table for 00030000
[0018.051] > PARTITION_MANAGER: Failed to publish partition.
[0018.056] W> Profiler not initialized
[0018.060] I> Entering 3p server
[0018.063] I> USB configuration success
[0019.311] I> Populate chip info
[0019.407] I> Populate eeprom info
[0019.411] I> Populate eeprom info for module cvm
[0019.416] > DEVICE_PROD: device prod is not initialized.
[0019.575] I> Rebooting : reboot-recovery
[0019.579] I> Reset to recovery mode
Hi anbuseelangna.barna,
Are you using “AGX Xavier Industrial” module on your custom carrier board?
What’s the current Jetpack in use?
Yes. we are using AGX Xavier Industrial. Jetpack 5.1
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
Can this module work on the devkit?
Could you also provide the flash log and the full serial console log for further check?
