Jetson AGX xavier not booting after flash
Hi, I have flashed the 8GB jetson AGX xavier module on custom carrier board and module is not booting.
The below is the log in debug port,
[0000.105] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.114] I> MB1 (prd-version: 1.5.1.2-t194-41334769-9ec1833d)
[0000.119] I> Boot-mode: Coldboot
[0000.122] I> Chip revision : A02
[0000.125] I> Bootrom patch version : 15 (correctly patched)
[0000.130] I> ATE fuse revision : 0x200
[0000.134] I> Ram repair fuse : 0x0
[0000.137] I> Ram Code : 0x4
[0000.139] I> rst_source : 0x0
[0000.142] I> rst_level : 0x0
[0000.145] I> Boot-device: eMMC
[0000.160] I> sdmmc DDR50 mode
[0000.165] W> No valid slot number is found in scratch register
[0000.170] W> Return default slot: _a
[0000.173] I> Active Boot chain : 0
[0000.177] I> Boot-device: eMMC
[0000.180] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.188] I> Temperature = 28000
[0000.191] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.195] W> Skipping boost for clk: BPMP_APB
[0000.199] W> Skipping boost for clk: AXI_CBB
[0000.203] W> Skipping boost for clk: AON_CPU_NIC
[0000.208] W> Skipping boost for clk: CAN1
[0000.211] W> Skipping boost for clk: CAN2
Can you please suggest what could be the issue?
Will it boot if you plug the module to nvidia devkit??
Hi Wayne,
No, it is not booting. But there was an issue with my target files.
I have corrected them and now it is fine.
Thank you
