Hello there,
We have designed a carrier board for Jetson AGX Xavier and trying to port Jetson AGX Xavier Industrial on it.
The current status is as follows:
- We have ported a device tree for JAXi on our carrier board.
- We can’t flash JAXi via SDKManager 1.7.3. It ends with the following error messages
15:42:03.028 - info: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: [ 14.4655 ] tegrarcm_v2 --oem platformdetails eeprom cvb /home/nvidia/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/bbd.bin
15:42:03.038 - info: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: [ 14.4675 ] MB2 Applet version 01.00.0000
15:42:03.235 - info: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: [ 14.8722 ] 000000003626070d: E> I2C: slave not found in slaves.
15:42:03.236 - info: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: [ 14.9268 ]
15:42:03.236 - info: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: [ 14.9269 ]
15:42:03.236 - info: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: [ 14.9321 ] tegradevflash_v2 --oem platformdetails eeprom cvb /home/nvidia/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/bbd.bin
15:42:03.249 - info: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: [ 14.9335 ] CPU Bootloader is not running on device.
15:42:03.249 - info: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: [ 15.0826 ]
15:42:03.255 - error: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: Error: Return value 4
15:42:03.256 - info: Event: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS - error is: Error: Return value 4
15:42:03.256 - info: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: Command tegradevflash_v2 --oem platformdetails eeprom cvb /home/nvidia/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/bbd.bin
15:42:03.283 - error: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: --- Error: Reading board information failed.
15:42:03.283 - info: Event: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS - error is: --- Error: Reading board information failed.
15:42:03.283 - info: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: [ Component Install Finished with Error ]
15:42:03.283 - info: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: [host] [ 684.00 KB used. Disk Avail: 227.13 GB ]
15:42:03.283 - info: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: [ NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP Install took 17s ]
15:42:03.284 - info: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS:
15:42:03.284 - error: command error code: 11
15:42:03.284 - info: Event: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS - error code is: 1011
15:42:03.284 - error: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: command terminated with error
15:42:03.284 - info: Event: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS - error is: command terminated with error
15:42:03.293 - info: Event: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS - install ended - failure
15:42:03.295 - info: Summary: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: Installation failed.
- We can flash JAXi via “flash.sh”. But the Ubuntu install process seems never completed and stuck in the orange background.
We don’t have any available AGX Dev kit left for AB testing.
Any help or possible solution is appreciated.
Best regards.
