I am currently trying to get an audio output on the I2S pins of the Jetson Xavier NX Board. My current problem is the missing soundcard for I2S (jetsonxaviernxa).
When I list up all recognized soundcards using cat /proc/asound/cards only the HDA card shows up.
I have attached my dmesg output below. dmesg_output.txt (59.6 KB)
Someone else used the NX before me and i can’t tell if he made some changes to the kernel or device tree. But, I am currently reinstalling the operating system so I can work with an clean environment.
[ 1.917184] tegra-asoc: sound: Can't retrieve clk clk_m
[ 1.917225] tegra-asoc:: probe of sound failed with error -2
Which would explain why the other soundcard is not there, however, it is not clear why this is happening. Yes sounds like a good idea to re-install L4T and see if the problem persists.
