L4T BSP Information:
R32 , REVISION: 7.2
Target Board Information:
Name: jetson-xavier-nx-devkit, Board Family: t186ref, SoC: Tegra 194,
OpMode: production, Boot Authentication: NS,
Disk encryption: disabled ,
copying soft_fuses(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)… done.
./tegraflash.py --chip 0x19 --applet “/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin” --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins “mb2_applet nvtboot_applet_t194.bin” --cmd “dump eeprom boardinfo cvm.bin;reboot recovery”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0086 ] Generating RCM messages
[ 0.0325 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[ 0.0351 ] Header already present for /home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[ 0.0565 ]
[ 0.0610 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0613 ] Assuming zero filled SBK key
[ 0.0645 ] tegrasign_v3.py --file /home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0648 ] Assuming zero filled SBK key
[ 0.1651 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[ 0.1754 ]
[ 0.2278 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.2628 ]
[ 0.2673 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[ 0.2697 ] RCM 0 is saved as rcm_0.rcm
[ 0.2778 ] RCM 1 is saved as rcm_1.rcm
[ 0.2779 ] RCM 2 is saved as rcm_2.rcm
[ 0.2779 ] List of rcm files are saved in rcm_list.xml
[ 0.2779 ]
[ 0.2780 ] Signing RCM messages
[ 0.2816 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.2818 ] Assuming zero filled SBK key
[ 0.2977 ] Copying signature to RCM mesages
[ 0.3007 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.3029 ]
[ 0.3031 ] Boot Rom communication
[ 0.3057 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.3072 ] RCM version 0X190001
[ 0.3085 ] Boot Rom communication completed
[ 1.3244 ]
[ 2.3301 ] tegrarcm_v2 --isapplet
[ 2.3323 ] Applet version 01.00.0000
[ 2.3475 ]
[ 2.3517 ] tegrarcm_v2 --ismb2
[ 2.3719 ]
[ 2.3763 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[ 2.3789 ]
[ 2.3823 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[ 2.3841 ] adding BCH for nvtboot_applet_t194.bin
[ 2.4185 ]
[ 2.4248 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 2.4249 ] Assuming zero filled SBK key
[ 2.4326 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[ 2.4373 ]
[ 2.4400 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[ 2.4415 ] Applet version 01.00.0000
[ 2.4598 ] Sending mb2
[ 2.4601 ] […] 100%
[ 2.4752 ]
[ 2.4791 ] tegrarcm_v2 --boot recovery
[ 2.4816 ] Applet version 01.00.0000
[ 2.5031 ]
[ 3.5086 ] tegrarcm_v2 --isapplet
[ 3.5143 ]
[ 3.5190 ] tegrarcm_v2 --ismb2
[ 3.5208 ] MB2 Applet version 01.00.0000
[ 3.5520 ]
[ 3.5558 ] tegrarcm_v2 --ismb2
[ 3.5584 ] MB2 Applet version 01.00.0000
[ 3.5919 ]
[ 3.5955 ] Retrieving board information
[ 3.5990 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 3.6009 ] MB2 Applet version 01.00.0000
[ 3.6201 ] Saved platform info in chip_info.bin
[ 3.6254 ] Chip minor revision: 2
[ 3.6256 ] Bootrom revision: 0xf
[ 3.6257 ] Ram code: 0x0
[ 3.6257 ] Chip sku: 0xde
[ 3.6257 ] Chip Sample: non es
[ 3.6257 ]
[ 3.6262 ] Retrieving EEPROM data
[ 3.6264 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 3.6285 ] MB2 Applet version 01.00.0000
[ 3.6506 ] Saved platform info in /home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 3.6853 ]
[ 3.6856 ] Rebooting to recovery mode
[ 3.6898 ] tegrarcm_v2 --ismb2
[ 3.6930 ] MB2 Applet version 01.00.0000
[ 3.7120 ]
[ 3.7120 ] Rebooting to recovery mode
[ 3.7158 ] tegrarcm_v2 --reboot recovery
[ 3.7177 ] MB2 Applet version 01.00.0000
[ 3.7460 ]
Board ID(3668) version(300) sku(0000) revision(B.0)
Copy /home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb to /home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb.rec
copying bctfile(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg)… done.
copying bctfile1(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)… done.
copying minratchet_config(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p3668.cfg)… done.
copying device_config(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-qspi-p3668.cfg)… done.
copying misc_cold_boot_config(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-sd-l4t.cfg)… done.
copying misc_config(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)… done.
copying pinmux_config(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p3668-a01.cfg)… done.
copying gpioint_config(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg)… done.
copying pmic_config(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p3668-0001-a00.cfg)… done.
copying pmc_config(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p3668-a01.cfg)… done.
copying prod_config(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p3668-0001-a00.cfg)… done.
copying scr_config(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)… done.
copying scr_cold_boot_config(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)… done.
copying bootrom_config(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p3668-0001-a00.cfg)… done.
copying dev_params(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-qspi.cfg)… done.
Existing bootloader(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
Making Boot image… done.
/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign boot.img kernel
version 1.0.0
[ 0.0006 ] Generating signature
[ 0.0034 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0036 ] Assuming zero filled SBK key : not reading
[ 0.0035 ] Generating ratchet blob
[ 0.0059 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0070 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0075 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0075 ]
[ 0.0076 ] header_magic: 414e4452
[ 0.0101 ] tegrahost_v2 --chip 0x19 --align 1_boot.img
[ 0.0117 ]
[ 0.0141 ] tegrahost_v2 --chip 0x19 0 --magicid KRNL --ratchet_blob ratchet_blob.bin --appendsigheader 1_boot.img zerosbk
[ 0.0156 ] adding BCH for 1_boot.img
[ 1.1969 ]
[ 1.2011 ] tegrasign_v3.py --key --list 1_boot_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 1.2013 ] Assuming zero filled SBK key : not reading
[ 1.3030 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_boot_sigheader.img.encrypt 1_boot_sigheader.img.hash zerosbk
[ 2.2405 ]
[ 2.2893 ] Signed file: /home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
l4t_sign_image.sh: chip 0x19: add 0x27cb800 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
l4t_sign_image.sh: the signed file is /home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
done.
Making recovery ramdisk for recovery image…
Re-generating recovery ramdisk for recovery image…
~/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader ~/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra
30412 blocks
_BASE_KERNEL_VERSION=4.9.253-tegra
~/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp/lib ~/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader ~/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra
66037 blocks
Making Recovery image…
copying recdtbfile(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb.rec)… done.
20+0 records in
20+0 records out
20 bytes copied, 0.00057802 s, 34.6 kB/s
Existing sosfile(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/bpmp_t194.bin) reused.
copying bpfdtbfile(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p3668-a00.dtb)… done.
Existing scefile(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-rce.img) reused.
Existing spefile(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing wb0boot(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tos-trusty_t194.img) reused.
Existing eksfile(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb)… done.
Copying nv_boot_control.conf to rootfs
/home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign kernel_tegra194-p3668-all-p3509-0000.dtb kernel_dtb
version 1.0.0
[ 0.0008 ] Generating signature
[ 0.0039 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0040 ] Assuming zero filled SBK key : not reading
[ 0.0039 ] Generating ratchet blob
[ 0.0065 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0078 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0082 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0082 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0082 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0082 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0082 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0082 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0082 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0082 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0082 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0082 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0082 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0082 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0082 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0082 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0082 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0083 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0083 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0083 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0083 ]
[ 0.0084 ] header_magic: d00dfeed
[ 0.0111 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p3668-all-p3509-0000.dtb
[ 0.0128 ]
[ 0.0155 ] tegrahost_v2 --chip 0x19 0 --magicid KDTB --ratchet_blob ratchet_blob.bin --appendsigheader 1_kernel_tegra194-p3668-all-p3509-0000.dtb zerosbk
[ 0.0170 ] adding BCH for 1_kernel_tegra194-p3668-all-p3509-0000.dtb
[ 0.0285 ]
[ 0.0333 ] tegrasign_v3.py --key --list 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0336 ] Assuming zero filled SBK key : not reading
[ 0.0421 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[ 0.0478 ]
[ 0.0488 ] Signed file: /home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate header for kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: chip 0x19: add 0x31f5f to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: the signed file is /home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
done.
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating kernel_tegra194-p3668-all-p3509-0000.dtb to rootfs… done.
Making system.img…
populating rootfs from /home/jensen/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/rootfs …
