Jetson xavier nx not booting jetpack v5
it got this error then after it proceed
Error: Return value 3
Command tegradevflash_v2 --pt flash.xml.bin --create
Failed flashing t186ref.
I didnt do anything but put it into recover mode again after this error and run the sudo command again.
And it just magically works!!!
Thanks a lot for helping. This booting problem bothers me so long…
ēœŸēš„éžåøøéžåøøę„Ÿč¬!
Not sure if this is due to usb cable quality. Sounds that the flash is not stable.
You can also try some other usb cable in future.
I wonder the same thing @WayneWWW asked, if it is a cable issue (or particular port or HUB issue). Are you using the USB cable supplied by NVIDIA, or is it a charger cable? Charger cables are notorious for failing with data.
Really…!? I use a charger cable 'cause the NX is actually not mine and the USB cable from NVIDIA is already missing before giving to me. I think that’s the reason…
I suspect over half of ā€œchargerā€ cables have so little copper in them (to save money) that 2/3 of them will either fail immediately, or else some time during data transfer.
