Hello:
Question about reading the Jetson Zavier NX pinmux spreadsheet. I am working on my own carrier card for this module and am needing more GPIO than what the reference carrier card provides. I see in the PIN Muxing Column a sub column for GPIO… some pins don’t have a name and some do, like for SDMMC_CLK pin 229 it can also be GPIO3_PO.00. Can any signal pin that has a GPIO name option be used as a GPIO and also its pin direction be dictated by the Pin Direction column? For example if I wanted to use pin 229 (default SDMMC_CLK) I could make it GPIO3_PO.00 and make its pin direciton BiDirectional?
Thanks,
mn3
