When I pull rtsp stream from network camera, the system will reboot.
I use jetpack4.6 and tegra 32.6.1, I wonder if I should downgrade jetpack version.
kern.log (1.0 MB)
using opencv:
def queue_img_put(q_put):
gst = "rtspsrc location=rtsp://admin:admin@x.x.x.x:554/Streaming/Channels/101 latency=0 ! rtph264depay ! h264parse ! omxh264dec ! videoconvert ! appsink"
cap = cv2.VideoCapture(gst)
# also reboot
# cap = cv2.VideoCapture("rtsp://admin:admin@x.x.x.x:554/Streaming/Channels/101")
fps = int(cap.get(cv2.CAP_PROP_FPS))
width = int(cap.get(cv2.CAP_PROP_FRAME_WIDTH))
height = int(cap.get(cv2.CAP_PROP_FRAME_HEIGHT))
while True:
is_opened, frame = cap.read()
if is_opened:
frame = np.copy(frame)
q_put.put(frame)
else:
None
if q_put.qsize() > 15:
q_put.get()
time.sleep(0.01)
else:
None
using vlc:
using gst-launch:
gst-launch-1.0 playbin uri=rtsp://admin:password@x.x.x.x:554/Streaming/Channels/101
Thanks a lot.
