Jetson xavier NX | soctherm: OC ALARM 0x00000002 continuously in the log
I am getting the below log continuously until i login in the console.
May i know the reason for it?
And how to solve it?
I am uisng jetson xavier nx som in our custom carrier board.
I have gone through same queries related to this topic in this forum but i dont understand the reason behind it… Kindly explain…
666.242322] soctherm: OC ALARM 0x00000002
[ 667.242585] soctherm: OC ALARM 0x00000002
[ 668.246844] soctherm: OC ALARM 0x00000002
[ 669.250543] soctherm: OC ALARM 0x00000002
Which part cannot understand?
Which post did you refer to?
It would be better sharing above info otherwise I would just copy another post for you.
I dont understand the reason behind this log…
i am using jetpack 5.1
Ask your hardware engineer and tell them your board hit under voltage situation.
Thank you
