Jetson Xavier or Nano + Thermal Camera FLIR A325
Are there sdk or drive to connect Jetson Xavier to the FLIR A325 thermal camera?
Are there sdk or drive to connect to Jetson nano on the FLIR A325 thermal camera?
The default system image not include it, need integrate it to Jetson system.
Maybe consult with vendor if can give relative information and help.
Hi:
The Video4Linux subsystem uses MIPI and some other low-level camera interfaces to connect to a sensor. Your A325 is supported by FLIR SDK - check out this
Note that those allow you to connect to a Windows or Linux x86 system. If you need to use the power of a Nano or Xavier, put in a FLIR support ticket and see if the can help. If you don’t get a response, ping me here and I’ll see if I can help.
Larry@FLIR
