Jetson
Hi I have a question about the Jetson device. I am working on a project using the Jetson AGX Orin Developer Kit to run DetectNet. jetson-inference/docs/detectnet-console-2.md at master · dusty-nv/jetson-inference · GitHub
We are planning on getting another low powered jetson to run the same DetectNet algorithm. The Jetson we are looking into is Jetson Orin Nano Super Developer Kit. I have the logs attached. Can you help me figure out if this jetson is sufficient to run the CV algorithm
Thank you
You can find some benchmark results for Orin series below:
Please also find the spec details of Orin series:
Orin Nano doesn’t have DLA/PVA and hardware encoder.
Please check if this will impact your use case.
