I am trying connect LI-IMX264-MIPI-M12.
nvidia@tegra-ubuntu:~$ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'RG12'
Name : 12-bit Bayer RGRG/GBGB
Size: Discrete 2464x2058
Interval: Discrete 0.029s (35.000 fps)
But i can not get image with v4l2-ctl(or gst-launch or nvgstcapture) in camera’s resolution.
nvidia@tegra-ubuntu:~$ v4l2-ctl -V --set-fmt-video=width=2464,height=2058,pixelformat=RG12 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=imx264.raw -d /dev/video0
VIDIOC_DQBUF: failed: Input/output error
Format Video Capture:
Width/Height : 2464/2058
Pixel Format : 'RG12'
Field : None
Bytes per Line : 5120
Size Image : 10536960
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
dmesg
[ 1933.750622] imx265 7-0010: imx265_power_on: power on
[ 1933.814269] imx265 7-0010: imx265_s_stream++ enable 1
[ 1933.854186] tegra-vi4 15700000.vi: Status: 4 channel:00 frame:0002
[ 1933.860502] tegra-vi4 15700000.vi: timestamp sof 1944465974240 eof 1944465983936 data 0x00000200
[ 1933.870155] tegra-vi4 15700000.vi: capture_id 23 stream 4 vchan 0
[ 1934.850460] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1935.854467] tegra-vi4 15700000.vi: ATOMP_FE syncpt timeout!
[ 1935.860911] imx265 7-0010: imx265_s_stream++ enable 0
[ 1935.898783] imx265 7-0010: imx265_power_off: power off
trace
nvidia@tegra-ubuntu:~$ sudo cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 22/22 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/5:0-2653 [005] ...1 1933.850424: rtos_queue_peek_from_isr_failed: tstamp:60763276164 queue:0x0b4a3c58
kworker/5:0-2653 [005] ...1 1933.850432: rtcpu_start: tstamp:60763277630
kworker/5:0-2653 [005] ...1 1933.902344: rtcpu_vinotify_handle_msg: tstamp:60764555860 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:635013268 data:0x00010000
kworker/5:0-2653 [005] ...1 1933.902346: rtcpu_vinotify_handle_msg: tstamp:60764562456 tag:CHANSEL_PXL_SOF channel:0x00 frame:2 vi_tstamp:635019551 data:0x00000001
kworker/5:0-2653 [005] ...1 1933.902347: rtcpu_vinotify_handle_msg: tstamp:60764562644 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:635019556 data:0x00000000
kworker/5:0-2653 [005] ...1 1933.902348: rtcpu_vinotify_handle_msg: tstamp:60764562780 tag:CHANSEL_FAULT channel:0x00 frame:2 vi_tstamp:635019854 data:0x00000200
kworker/5:0-2653 [005] ...1 1933.902349: rtcpu_vinotify_handle_msg: tstamp:60764563601 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:2 vi_tstamp:635020782 data:0x08000000
kworker/5:0-2653 [005] ...1 1933.902349: rtcpu_vinotify_handle_msg: tstamp:60764563733 tag:CHANSEL_FAULT_FE channel:0x10 frame:2 vi_tstamp:635020808 data:0x00000001
kworker/5:0-2653 [005] ...1 1933.902350: rtcpu_vinotify_handle_msg: tstamp:60764563906 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:635020811 data:0x00000000
kworker/5:0-2653 [005] ...1 1934.006342: rtos_queue_peek_from_isr_failed: tstamp:60768277050 queue:0x0b4a3c58
kworker/5:0-2653 [005] ...1 1934.162403: rtos_queue_peek_from_isr_failed: tstamp:60773277641 queue:0x0b4a3c58
kworker/5:0-2653 [005] ...1 1934.318400: rtos_queue_peek_from_isr_failed: tstamp:60778278147 queue:0x0b4a3c58
kworker/5:0-2653 [005] ...1 1934.474465: rtos_queue_peek_from_isr_failed: tstamp:60783278716 queue:0x0b4a3c58
kworker/5:0-2653 [005] ...1 1934.630397: rtos_queue_peek_from_isr_failed: tstamp:60788279172 queue:0x0b4a3c58
kworker/5:0-2653 [005] ...1 1934.786400: rtos_queue_peek_from_isr_failed: tstamp:60793279663 queue:0x0b4a3c58
kworker/5:0-2653 [005] ...1 1934.942429: rtos_queue_peek_from_isr_failed: tstamp:60798280199 queue:0x0b4a3c58
kworker/5:0-2653 [005] ...1 1935.098399: rtos_queue_peek_from_isr_failed: tstamp:60803280681 queue:0x0b4a3c58
kworker/5:0-2653 [005] ...1 1935.254394: rtos_queue_peek_from_isr_failed: tstamp:60808281185 queue:0x0b4a3c58
kworker/5:0-2653 [005] ...1 1935.462389: rtos_queue_peek_from_isr_failed: tstamp:60813281694 queue:0x0b4a3c58
kworker/5:0-2653 [005] ...1 1935.618389: rtos_queue_peek_from_isr_failed: tstamp:60818282198 queue:0x0b4a3c58
kworker/5:0-2653 [005] ...1 1935.774374: rtos_queue_peek_from_isr_failed: tstamp:60823282772 queue:0x0b4a3c58
kworker/5:0-2653 [005] ...1 1935.878827: rtos_queue_peek_from_isr_failed: tstamp:60827270917 queue:0x0b4a3c58
In this way im getting PIXEL_SHORT_LINE error.
So i changed resolution to 1936x2058 and it looks like it is ok, but image (and video) is broken.
nvidia@tegra-ubuntu:~$ v4l2-ctl -V --set-fmt-video=width=1936,height=2058,pixelformat=RG12 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=imx264.raw -d /dev/video0
Width/Height : 1936/2058
Field : None
Bytes per Line : 4096
Size Image : 8429568
Colorspace : sRGB
Flags :
dmesg
[ 2910.160020] imx265 7-0010: imx265_power_on: power on
[ 2910.194850] imx265 7-0010: imx265_s_stream++ enable 1
[ 2910.373120] imx265 7-0010: imx265_s_stream++ enable 0
[ 2910.425926] imx265 7-0010: imx265_power_off: power off
trace
kworker/5:0-2653 [005] ...1 2910.199451: rtos_queue_peek_from_isr_failed: tstamp:91275171494 queue:0x0b4a3c58
kworker/5:0-2653 [005] ...1 2910.199457: rtcpu_start: tstamp:91275172707
kworker/5:0-2653 [005] ...1 2910.251425: rtcpu_vinotify_handle_msg: tstamp:91276401300 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:1082087651 data:0x00010000
kworker/5:0-2653 [005] ...1 2910.251428: rtcpu_vinotify_handle_msg: tstamp:91276407286 tag:CHANSEL_PXL_SOF channel:0x00 frame:2 vi_tstamp:1082093515 data:0x00000001
kworker/5:0-2653 [005] ...1 2910.251429: rtcpu_vinotify_handle_msg: tstamp:91276407432 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:1082093521 data:0x00000000
kworker/5:0-2653 [005] ...1 2910.251430: rtcpu_vinotify_handle_msg: tstamp:91276409587 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:2 vi_tstamp:1082095960 data:0x08000000
kworker/5:0-2653 [005] ...1 2910.303478: rtcpu_vinotify_handle_msg: tstamp:91277270002 tag:CHANSEL_PXL_EOF channel:0x00 frame:2 vi_tstamp:1082956089 data:0x08090002
kworker/5:0-2653 [005] ...1 2910.303484: rtcpu_vinotify_handle_msg: tstamp:91277270142 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:1082956204 data:0x00000000
kworker/5:0-2653 [005] ...1 2910.303485: rtcpu_vinotify_handle_msg: tstamp:91277282551 tag:CHANSEL_PXL_SOF channel:0x00 frame:1 vi_tstamp:1082968780 data:0x00000001
kworker/5:0-2653 [005] ...1 2910.303487: rtcpu_vinotify_handle_msg: tstamp:91277282735 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:1082968787 data:0x00000000
kworker/5:0-2653 [005] ...1 2910.303488: rtcpu_vinotify_handle_msg: tstamp:91277284761 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:1 vi_tstamp:1082971118 data:0x08000000
kworker/5:0-2653 [005] ...1 2910.303490: rtcpu_vinotify_handle_msg: tstamp:91278145289 tag:CHANSEL_PXL_EOF channel:0x00 frame:1 vi_tstamp:1083831355 data:0x08090002
kworker/5:0-2653 [005] ...1 2910.303492: rtcpu_vinotify_handle_msg: tstamp:91278145467 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:1083831470 data:0x00000000
kworker/5:0-2653 [005] ...1 2910.303493: rtcpu_vinotify_handle_msg: tstamp:91278157847 tag:CHANSEL_PXL_SOF channel:0x00 frame:2 vi_tstamp:1083844046 data:0x00000001
kworker/5:0-2653 [005] ...1 2910.303495: rtcpu_vinotify_handle_msg: tstamp:91278158076 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:1083844053 data:0x00000000
kworker/5:0-2653 [005] ...1 2910.303496: rtcpu_vinotify_handle_msg: tstamp:91278160966 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:2 vi_tstamp:1083847303 data:0x08000000
kworker/5:0-2653 [005] ...1 2910.355460: rtcpu_vinotify_handle_msg: tstamp:91279020528 tag:CHANSEL_PXL_EOF channel:0x00 frame:2 vi_tstamp:1084706621 data:0x08090002
kworker/5:0-2653 [005] ...1 2910.355467: rtcpu_vinotify_handle_msg: tstamp:91279020671 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:1084706736 data:0x00000000
kworker/5:0-2653 [005] ...1 2910.355469: rtcpu_vinotify_handle_msg: tstamp:91279033089 tag:CHANSEL_PXL_SOF channel:0x00 frame:1 vi_tstamp:1084719313 data:0x00000001
kworker/5:0-2653 [005] ...1 2910.355471: rtcpu_vinotify_handle_msg: tstamp:91279033273 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:1084719319 data:0x00000000
kworker/5:0-2653 [005] ...1 2910.355472: rtcpu_vinotify_handle_msg: tstamp:91279035961 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:1 vi_tstamp:1084722318 data:0x08000000
kworker/5:0-2653 [005] ...1 2910.355474: rtcpu_vinotify_handle_msg: tstamp:91279895773 tag:CHANSEL_PXL_EOF channel:0x00 frame:1 vi_tstamp:1085581887 data:0x08090002
kworker/5:0-2653 [005] ...1 2910.355476: rtcpu_vinotify_handle_msg: tstamp:91279895876 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:1085582002 data:0x00000000
kworker/5:0-2653 [005] ...1 2910.355478: rtcpu_vinotify_handle_msg: tstamp:91279908341 tag:CHANSEL_PXL_SOF channel:0x00 frame:2 vi_tstamp:1085594578 data:0x00000001
kworker/5:0-2653 [005] ...1 2910.355479: rtcpu_vinotify_handle_msg: tstamp:91279908488 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:1085594585 data:0x00000000
kworker/5:0-2653 [005] ...1 2910.355481: rtcpu_vinotify_handle_msg: tstamp:91279912374 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:2 vi_tstamp:1085598746 data:0x08000000
kworker/5:0-2653 [005] ...1 2910.355487: rtos_queue_peek_from_isr_failed: tstamp:91280172419 queue:0x0b4a3c58
kworker/5:0-2653 [005] ...1 2910.407765: rtcpu_vinotify_handle_msg: tstamp:91280771088 tag:CHANSEL_PXL_EOF channel:0x00 frame:2 vi_tstamp:1086457153 data:0x08090002
kworker/5:0-2653 [005] ...1 2910.407805: rtcpu_vinotify_handle_msg: tstamp:91280771267 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:1086457267 data:0x00000000
kworker/5:0-2653 [005] ...1 2910.407841: rtos_queue_peek_from_isr_failed: tstamp:91280946036 queue:0x0b4a3c58
