Not working custom camera driver
I made cutom camera driver from nv_imx185.c.
and my camera is connected to mipi csi cphy with 3 lanes.
I tried to stream by v4l2-ctl but it is failed.
which part would be checked?
l45 version : 35.5.0
v4l2-ctl
$ v4l2-ctl -d /dev/video0 --set-fmt-video=width=3840,height=2160,pixelformat=RG10 \
> --set-ctrl bypass_mode=0 --stream-mmap --stream-count=3 --stream-to=test.raw --verbose
VIDIOC_QUERYCAP: ok
VIDIOC_S_EXT_CTRLS: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
Format Video Capture:
        Width/Height      : 3840/2160
        Pixel Format      : 'RG10' (10-bit Bayer RGRG/GBGB)
        Field             : None
        Bytes per Line    : 7680
        Size Image        : 16588800
        Colorspace        : sRGB
        Transfer Function : Default (maps to sRGB)
        YCbCr/HSV Encoding: Default (maps to ITU-R 601)
        Quantization      : Default (maps to Full Range)
        Flags             :
                VIDIOC_REQBUFS returned 0 (Success)
                VIDIOC_QUERYBUF returned 0 (Success)
                VIDIOC_QBUF returned 0 (Success)
                VIDIOC_STREAMON returned 0 (Success)
cap dqbuf: 0 seq:      0 bytesused: 16588800 ts: 0.000000 (error, ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq:      1 bytesused: 16588800 ts: 0.000000 (error, ts-monotonic, ts-src-eof)
cap dqbuf: 2 seq:      2 bytesused: 16588800 ts: 0.000000 (error, ts-monotonic, ts-src-eof)
cap dqbuf: 3 seq:      3 bytesused: 16588800 ts: 0.000000 (error, ts-monotonic, ts-src-eof)
kernel log
[  281.519842] imx858 2-001a: imx858_power_on: power on
[  281.550621] bwmgr API not supported
[  281.561165] imx858 2-001a: imx858_set_mode mode: 0
[  281.564790] imx858 2-001a: line_length_inck 716
[  281.564792] imx858 2-001a: ivtpxck_period 64
[  281.647164] imx858 2-001a: 	i2c write table, 0x0136 = 18
[  281.647178] imx858 2-001a: imx858_start_streaming
[  281.727827] imx858 2-001a: 	i2c write table, 0x0136 = 18
[  281.968987] imx858 2-001a: 	i2c write table, 0x0100 = 01
[  281.969200] imx858 2-001a: 	i2c read, 0x0005 = 07
[  281.969203] imx858 2-001a: 	i2c read, 0x0100 = 01
[  284.306137] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  284.315293] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  284.324879] (NULL device *): vi_capture_control_message: NULL VI channel received
[  284.332648] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  284.343370] (NULL device *): vi_capture_control_message: NULL VI channel received
[  284.351419] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  286.862150] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  286.871311] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  286.880978] (NULL device *): vi_capture_control_message: NULL VI channel received
[  286.888740] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  286.899440] (NULL device *): vi_capture_control_message: NULL VI channel received
[  287.922135] tegra194-vi5 13e40000.host1x:vi0@15c00000: capture control message timed out
[  287.930537] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_control_send_message: failed to send IVC control message
[  288.974178] tegra194-vi5 13e40000.host1x:vi0@15c00000: capture control message timed out
[  288.982610] tegra-camrtc-capture-vi tegra-capture-vi: vi capture setup failed
[  288.989989] tegra-camrtc-capture-vi tegra-capture-vi: fatal: error recovery failed
trace log
# tracer: nop
# entries-in-buffer/entries-written: 23/23   #P:12
#                                _-----=> irqs-off
#                               / _----=> need-resched
#                              | / _---=> hardirq/softirq
#                              || / _--=> preempt-depth
#                              ||| /     delay
#           TASK-PID     CPU#  ||||   TIMESTAMP  FUNCTION
     kworker/8:2-165     [008] ....   162.646345: rtcpu_string: tstamp:5963914735 id:0x04010000 str:"VM0 deactivating."
        v4l2-ctl-3654    [005] ....   281.499616: tegra_channel_open: vi-output, imx858 2-001a
        v4l2-ctl-3654    [005] ....   281.519819: tegra_channel_set_power: imx858 2-001a : 0x1
        v4l2-ctl-3654    [005] ....   281.519832: camera_common_s_power: status : 0x1
        v4l2-ctl-3654    [000] ....   281.537951: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-3654    [000] ....   281.537956: csi_s_power: enable : 0x1
        v4l2-ctl-3654    [000] ....   281.538611: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt c4
        v4l2-ctl-3654    [002] ....   281.547116: tegra_channel_set_stream: enable : 0x1
        v4l2-ctl-3654    [003] ....   281.560704: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-3654    [003] ....   281.560708: csi_s_stream: enable : 0x1
        v4l2-ctl-3654    [003] ....   281.561145: tegra_channel_set_stream: imx858 2-001a : 0x1
     kworker/8:2-165     [008] ....   281.578139: rtcpu_string: tstamp:9679397988 id:0x04010000 str:"VM0 activating."
     kworker/8:2-165     [008] ....   281.578143: rtcpu_vinotify_event: tstamp:9679917019 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:309747000576 data:0x359d580010000000
     kworker/8:2-165     [008] ....   281.578143: rtcpu_vinotify_event: tstamp:9679917193 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:309747007040 data:0x0000000031000001
     kworker/8:2-165     [008] ....   281.578143: rtcpu_vinotify_event: tstamp:9679917388 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:309747052864 data:0x359d550010000000
     kworker/8:2-165     [008] ....   281.578144: rtcpu_vinotify_event: tstamp:9679917556 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:309747059424 data:0x0000000031000002
 vi-output, imx8-3656    [000] ....   284.351271: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt c4
     kworker/8:2-165     [008] ....   284.398150: rtcpu_vinotify_event: tstamp:9767483054 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:312551408960 data:0x359d580010000000
     kworker/8:2-165     [008] ....   284.398153: rtcpu_vinotify_event: tstamp:9767483189 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:312551434560 data:0x0000000031000001
     kworker/8:2-165     [008] ....   284.398153: rtcpu_vinotify_event: tstamp:9767483342 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:312551445088 data:0x359d550010000000
     kworker/8:2-165     [008] ....   284.398153: rtcpu_vinotify_event: tstamp:9767483474 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:312551481344 data:0x0000000031000002
 vi-output, imx8-3656    [000] ....   287.942554: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt c4
     kworker/8:2-165     [008] ....   295.222147: rtcpu_string: tstamp:10105636302 id:0x04010000 str:"VM0 deactivating."
device tree setting
	overlay-name = "Jetson Camera IMX858";
	jetson-header-name = "Jetson AGX CSI Connector";
	compatible = "nvidia,p3737-0000+p3701-0000" , "nvidia,p3737-0000+p3701-0004", "nvidia,p3737-0000+p3701-0005", "nvidia,p3737-0000+p3701-0008";
	fragment@0 {
		target-path = "/";
		__overlay__ {
			tegra-capture-vi {
				num-channels = <1>;
				ports {
					#address-cells = <1>;
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						status = "okay";
						liimx858_vi_in0: endpoint {
							status = "okay";
							port-index = <0>;
							bus-width = <3>;
							remote-endpoint = <&liimx858_csi_out0>;
			host1x@13e00000 {
				nvcsi@15a00000 {
					num-channels = <1>;
					#size-cells = <0>;
					channel@0 {
						status = "okay";
						reg = <0>;
						ports {
							#size-cells = <0>;
							port@0 {
								status = "okay";
								reg = <0>;
								liimx858_csi_in0: endpoint@0 {
									status = "okay";
									port-index = <0>;
									bus-width = <3>;
									remote-endpoint = <&liimx858_imx858_out0>;
							port@1 {
								status = "okay";
								reg = <1>;
								liimx858_csi_out0: endpoint@1 {
									status = "okay";
									remote-endpoint = <&liimx858_vi_in0>;
			i2c@3180000 {
				imx858_a@1a {
					status = "okay";
					compatible = "nvidia,imx858";
					reg = <0x1a>;
					#size-cells = <0>;
					avdd-reg = "vana";
					vana-supply = <&p3737_avdd_cam_2v8>;
					clocks = <&bpmp_clks TEGRA234_CLK_EXTPERIPH1>,
								<&bpmp_clks TEGRA234_CLK_EXTPERIPH1>;
					clock-names = "extperiph1", "pllp_grtba";
					mclk = "extperiph1";
					reset-gpios = <&tegra_main_gpio CAM0_RST_L GPIO_ACTIVE_HIGH>;
					devnode = "video0";
					/* Physical dimensions of sensor */
					physical_w = "15.0";
					physical_h = "12.5";
					sensor_model ="imx858";
					post_crop_frame_drop = "0";
					/* Convert Gain to unit of dB (decibel) befor passing to kernel driver */
					use_decibel_gain = "true";
					/* if true, delay gain setting by one frame to be in sync with exposure */
					delayed_gain = "true";
					/* enable CID_SENSOR_MODE_ID for sensor modes selection */
					use_sensor_mode_id = "true";
					mode0 { /*mode IMX858_MODE_3840X2160_10BIT_30FPS*/
						mclk_khz = "24000";
						num_lanes = "3";
						phy_mode = "CPHY";
						discontinuous_clk = "no";
						dpcm_enable = "false";
						cil_settletime = "0";
						dynamic_pixel_bit_depth = "10";
						csi_pixel_bit_depth = "10";
						mode_type = "bayer";
						pixel_phase = "rggb";
						active_w = "3840";
						active_h = "2160";
						readout_orientation = "0";
						line_length = "4536"; /* pixel clock*/
						inherent_gain = "1";
						pix_clk_hz = "608228571"; /* pixel rate */
						line_length_inck = "716";
						ivtpxck_period ="64"; /*155.2MHz ivtpxck period, unit 0.1 nsec */
						gain_factor = "10";
						min_gain_val = "31"; /* 3.1 dB */
						max_gain_val = "300"; /* 30 dB */
						step_gain_val = "1"; /* 0.1 */
						default_gain = "31";
						min_hdr_ratio = "1";
						max_hdr_ratio = "1";
						framerate_factor = "1000000";
						min_framerate = "1500000"; /* 1.5 */
						max_framerate = "60000000"; /* 30 */
						step_framerate = "1";
						default_framerate= "30000000";
						exposure_factor = "1000000";
						min_exp_time = "30"; /* us */
						max_exp_time = "660000"; /* us */
						step_exp_time = "1";
						default_exp_time = "33334";/* us */
						embedded_metadata_height = "2";
					mode1 { /*mode IMX858_MODE_4032X3024_10BIT_30FPS*/
						mclk_khz = "24000";
						num_lanes = "3";
						phy_mode = "CPHY";
						active_w = "4032";
						active_h = "3024";
						line_length = "5783"; /* pixel clock*/
						pix_clk_hz = "548571429"; /* pixel rate */
						line_length_inck = "1012";
						ivtpxck_period ="45"; /*219.6MHz ivtpxck period, unit 0.1 nsec */
						gain_factor = "10";
						step_gain_val = "2"; /* 0.1 */
						max_framerate = "30000000"; /* 30 */
					ports {
						#size-cells = <0>;
						port@0 {
							reg = <0>;
							liimx858_imx858_out0: endpoint {
								port-index = <0>;
								bus-width = <3>;
								remote-endpoint = <&liimx858_csi_in0>;
			tegra-camera-platform {
				compatible = "nvidia, tegra-camera-platform";
				num_csi_lanes = <3>;
				max_lane_speed = <2400000>;
				min_bits_per_pixel = <10>;
				vi_peak_byte_per_pixel = <2>;
				vi_bw_margin_pct = <25>;
				isp_peak_byte_per_pixel = <5>;
				isp_bw_margin_pct = <25>;
				modules {
					module0 {
						status = "okay";
						badge = "imx858_bottom_liimx858";
						position = "bottom";
						orientation = "0";
						drivernode0 {
							status = "okay";
							pcl_id = "v4l2_sensor";
							devname = "imx858 2-001a";
							proc-device-tree = "/proc/device-tree/i2c@3180000/imx858_a@1a";
						drivernode1 {
							status = "okay";
							pcl_id = "v4l2_lens";
			};//tegra-camera-platform
		}; //__overlay__
Looks like NVCSI/VI didn’t receive any data from the sensor.
Maybe probe the MIPI signal to confirm.
Is this situation possible if the MIPI-related settings are incorrect on Jetson ?
( pix_clk_hz, line_length, num_lanes and etc… in device tree setting)
If possibe, what parameter would be consider ?
Confirm the port-index, bus-width, pix_clk_hz/serdes_pix_clk_hz
I used below equation.
Is it correct calclation?
sensor symbol rate is 887Msps(symbols per second) and it is cphy, 3 lanes, rggb10.
pix_clk_hz = 887M * (16/7) * 3 / 10 = 608228571
thanks
