Joint Target Position not working
Hi, I’m having an issue where when I try to change the Target Position of my joint using the Angular Drive nothing happens. If I change the Target Velocity it works as expected. I’m not sure if I’m missing some configuration step to make the Target Position work. Any help is highly appiciated!
Hi @malthe1
  • For position controlled joints, set a high stiffness and relatively low or zero damping.
  • For velocity controller joints, set a high damping and zero stiffness.
https://docs.omniverse.nvidia.com/isaacsim/latest/gui_tutorials/tutorial_gui_simple_robot.html?#add-joint-drive
