Get_joint_velocities incorrect?
I am running a simulation task using OmniIsaacGymEnvs. The simulation has reached steady-state and the robot is stationary (no joints are visibly moving).
Calling get_joint_velocities() on the ArticulationView returns non-zero values (+/- 0.3). Why would this be? Are the joint velocities relative to the joint itself, or relative to some other frame? The current targets are being set using set_joint_position_targets()
Please refer to Joint Velocities Incorrect? · Issue #101 · NVIDIA-Omniverse/OmniIsaacGymEnvs (github.com)
