Joint Drive Force Not Working, but Joint Drive Acceleration is. How to set joint force in UI?
Hi Community,
I watched an omniverse video describing how to use joint force and target position in the Isaac UI to simulate a joint rotating or moving. When I tried to apply that knowledge to my own model, joint drive force + target position did nothing, but joint drive acceleration + target position did…
I’m using a typical revolute joint with angular drive and have uploaded a video of an example video (upload tool won’t allow me to attach USD of the project).
All help is appreciated,
Thank you!
Solution:
The stiffness and target position properties of the angular drive are too low. I set the stiffness to 100,000 and target position to 80,000 and it worked as expected.
Those are some extremely high gains. Is this a unit thing then?
